20 Most Recent
Yamata FY812 Mechanical Sewing Machine Questions & Answers
The stiches become loose after few seconds after i start sewing
I had a problem similar to this-- when sewing, tons of thread was bunching and looping out of the stitches instead of a nice neat stitch. I finally figured out that this old metal bobbin I put in was incompatible. I switched to a plastic bobbin (the kind like that which came with the sewing machine) and the stitches looked fine.
Marie Osmond emotions embroidery machine...how do i delete saved?
Check the tension. Bobbin tension. You need to use only Isacord thread. The cheap stuff will get caught and break the needle everytime.
YES you can delete designs. When the screen is up that is showing you what it is stitching. Click on grey box that pulls up everything you have ever stitched and click on one and then select delete.
Feiyue
The Yamata sewing machines also go
under about 6 other names AEG YAMATA HOMEDREAMFEIYUE
PRIMERA VICTORIA . There is a PDF Download of a Universal
Manual for these models It is for many models from a FY700 up to
NM900. The PDF is in English & Chinese and can be downloaded
FREE from here
http://www.hennyreimerink.nl/MANUALS/FY700-English_Chinese.PDF
Yamta fy812
Am looking for the manual for the Yamata FY812 sewing machine. Anyone have one or know where I can find one?
Thank you..
My manual got lost, need
look on you tube for overlocker parts instruction.generally the needle is removed by loosenening a little screw which is pushing on the needle from the from.
sewingmanual.com has manuals for sale
I really struggle to use
Hi Karen,
I see the diagram on the machine, yet I cannot locate instructions online to use the threading unit. It would seem to me it is like using an old style hand threader for a hand needle, just set the thread's 'helper' as it were, as I can't see what it is on this photo or any other, into the needle, then place the thread into it, and release it, it should pull it through the eye. Finish by pulling the thread through by hand. The only other hint I can provide is that possibly your needle is too high or low when trying to place the thread into it. There are some very good youtube videos for threading a machine. Some go through the entire machine, some focus on various parts of it. A good search there may help you as well.
Hope I have been of some assistance,
Joe
My daughter bought a homedream
here are some site to try, I suggest to call them or email & ask them about the foot pedal
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingsupplywarehouse.com
sewforless.com
Hello I am wondering if
Hi, it uses low shank ,but you can also use the high for high performance level..
Both works very well...
What would you be looking for adaptor for ?is yours damaged..?
You can get what ever part your looking for from the below link..
http://www.sew4less.com/browse.php
Take care..
Ive lost the power lead
you should be able to buy one at any sewing machine outlet if they don't have one in stock they should be able to get one in for you
