20 Most Recent Copystar CS-1820 Copier Questions & Answers
0answers
Printing and copying cuts off 1/2 inch off the top
You will need to replace the registration clutch. It is slipping causing a delay in feeing.
3/10/2014 4:03:34 PM • Copystar CS-1820... • Answered on Mar 10, 2014
I HAVE A COPYSTAR CS1810
This code indicates a fault with the Fuser Unit/Thermistor or PS-PCB and should not be reset until the fault is corrected.
You could try resetting the fault as follows but this may damage the machine further.
Turn the copier off, while holding down the Size Select Key turn the copier on and keep it pressed until the copier shuts down.
6/17/2011 4:46:42 PM • Copystar CS-1820... • Answered on Jun 17, 2011
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
3/25/2011 11:35:46 AM • Copystar CS-1820... • Answered on Mar 25, 2011
How to change the toner
1 Open the top cover.
2 Open the front cover.
3 Lift the process unit, together with the toner container, out of the machine and place it on a clean, level surface.
Do not stand the process unit on end and never expose the drum to normal lighting for more than five minutes.
4 Pull the lock lever towards to the UNLOCK position then pull the toner container release lever to the right.
5 Gently remove the old toner container. Put it in the supplied plastic bag and dispose of it according to local rules and regulations.
6 Shake the new toner container horizontally 5 or 6 times to distributed the toner inside.
7 Remove the orange protective seal.
8 Align the knob on the left side of the container with the groove in the process unit and insert it. Push on the PUSH HERE marks until the container clicks into place.
9 Push the lock lever back into its locked position (away from you).
Clean the charge and registration roller.
Refer to Cleaning the Charger and the Registration Roller on page 5-4.
2/23/2011 12:10:46 AM • Copystar CS-1820... • Answered on Feb 23, 2011
On the copystar 1815 I have an error message that
when machine is on hold down stop key, start, left exposure. release them and press start. display will show U000. self status. key in 163 and press start twice
9/13/2010 6:09:03 AM • Copystar CS-1820... • Answered on Sep 13, 2010
Does the copystar CS -1820
the machine does not have duplex capabilities
9/13/2010 5:53:24 AM • Copystar CS-1820... • Answered on Sep 13, 2010
How to do a factory reset on CS-1820
go to the simulation by keying 1087 1087 and then key 21 to initialize
all memory
9/9/2010 5:59:37 AM • Copystar CS-1820... • Answered on Sep 09, 2010
How do I replace the toner of my Copystar CS-1820?
Open the top door
While sliding the blue lever, pick the used cart out.'Shake the new cart well, snap down both sides.
Close door
6/16/2010 11:10:00 PM • Copystar CS-1820... • Answered on Jun 16, 2010
Screen reads waste toner full
Remove the entire imaging unit
Unscrew the cap on the right side of the unit 1 chrome screw
Dump the waste toner out....very messy, do it outdoors
Replace the cap
Reinstall imaging unit
Power off and on again
6/6/2010 12:53:56 AM • Copystar CS-1820... • Answered on Jun 06, 2010
Does this copier work with Windows 7
Hello sir; I don't think so!
1/16/2010 5:31:46 PM • Copystar CS-1820... • Answered on Jan 16, 2010
How to reset gs-1820 copystar to factory
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
then use the arrow keys to get to u020
and select and then run the reset...
these machines do not automatically restart so you will have to flip the power switch manually to reset the machine
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
12/10/2009 1:59:17 PM • Copystar CS-1820... • Answered on Dec 10, 2009
Error code c6300
The code C-630 indicates an abnormally high fixing temperature.
Check the thermistor, if it is shorted, replace.
the Fixing Heater Control Circuit is located on the power source PCB> relace as needed.
9/10/2009 5:55:07 AM • Copystar CS-1820... • Answered on Sep 10, 2009
Clearing code c7980
email me at low_toner @yahoo.com indicate your location
8/30/2009 12:53:08 AM • Copystar CS-1820... • Answered on Aug 30, 2009
37 questions posted
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Copystar Office Equipment & Supplies
Most Popular Question
broke one hinges doc feeder when find
  • Office Equipment & Supplies
