20 Most Recent Citizen Silhouette Eco Drive Gold Tone EW9202 96P Watch for Women Questions & Answers
How can I resize a citizen watch with an
If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band.
These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal.
If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
12/2/2009 3:32:01 AM • Citizen... • Answered on Dec 02, 2009
Citizen eco-drive wr 200 manual
I'll need more information about the watch. WR200 is not the model number. It is the depth in metres it is water resistant to. The serial number is usually engraved on the back plate of the watch. The bit against your skin when you're wearing it. It's the number marked in red in the photo I've attached. Is this a digital watch, a watch with hands or does it have both? Comment below with the serial number and I'll try to help you more. img_0876-undefined-undefined-0.jpeg
11/16/2023 12:23:33 PM • Citizen Watches • Answered on Nov 16, 2023
Where can I find the Bl5400-52a citizen watch instruction manual?
Citizen Watches has a full and a simple instruction manual for the BL5400-52A on the product site: https://www.citizenwatches.com.au/products/bl5400-52a . Look on the right-hand side of the page below the Find a Retailer link. The current link to the Full Instructions is https://www.citizenwatch-global.com/support/pdf/e810/e.pdf I hope this helps. Cindy Wells
4/9/2023 10:37:26 PM • Citizen Watches • Answered on Apr 09, 2023
Can you please tell me the battery number. Thanks
Movement Brand Miyota Mechanism quartz Battery Renata R364 364 / SR621SW Battery
3/11/2023 6:43:03 PM • Citizen Watches • Answered on Mar 11, 2023
How to tell when the solar batteries in a Citizen watch go bad
when it doesnt power on
3/3/2023 4:06:16 PM • Citizen Watches • Answered on Mar 03, 2023
How to set date in eco drive wr 100
Adjust time date for eco drive wr100
11/22/2022 7:41:21 AM • Citizen Watches • Answered on Nov 22, 2022
Why does my Citizen watch say 'do not open service centre repair only' ?
Probably because it is gasket sealed. Have a read of this Tip I wrote. https://www.fixya.com/support/r27181038-changing_watch_batteries ..
6/19/2022 11:25:09 PM • Citizen Watches • Answered on Jun 19, 2022
Citizen AT4010-50E Men's Watch. What is the part number of case back gasket for it please?
Not available anywhere. Service Centre repair only. When you do the case gasket, you do the button gaskets at the same time. https://www.google.com/search?q=citizen+AT4010-50E+gasket ..
6/19/2022 11:19:00 PM • Citizen Watches • Answered on Jun 19, 2022
2answers
I have an old Citizen
hi, I'm from Italy and changed the batteries just 2 days ago - theer are three batteries inside this watch - in a normal shop selling citizen watches.....
I think youhave just to change shop....
5/16/2022 11:19:25 AM • Citizen Watches • Answered on May 16, 2022
Good morning. My watch Citizen AP1046-02A. What bateri I can buy'?
Georgi from researching this watch it utilises an eco drive it may have a capacitor that charges up from a light source. rather than a battery if it is not charging up the capacitor may be the problem. https://fixmywatch.co.uk/blog/why-we-dont-offer-a-battery-replacement-on-a-citizen-eco-drive/ the part number may be 295-6700
1/20/2022 8:19:00 AM • Citizen Watches • Answered on Jan 20, 2022
How do i set time on radio controlled wrist watch 3 atm
The point of a radio-controlled watch is that you should not have to move the hands manually. It is meant to respond to a time signal send from various places in the USA, UK, Germany, Japan and (I think) China. The signal's strength varies considerably, depending on where you are located and the ambient temperature. It may need some application and persistence to get the watch synchronized with the signal, this will cause the hands to move to the correct local time - even then it may need correction if you are in a different UTC time zone or on Daylight Saving Time (DST) locally. Not knowing the make complicates the validity of any information. I have found that the sync signal is broadcast on the hour for about five minutes and is best received at night where the signal travels further. Ensure your watch is fully charged and leave your watch by a window overnight for best results. If you still have difficulty, use an internet search to find the nearest broadcast station to where you are and work out which direction-facing window is best sited to face it. I have two RC watches - one Citizen and one Casio. One likes to have the left side of the watch facing the window and the other favours the 12 o'clock facing the window, As I don't know the make of your watch I would recommend trying to place it in various orientations until you find one that works for you. I have found the whole set up performs best in cold air situations - and so are more reliable in the winter. Guessing further, If you bring up the signal display function it may force the watch into signal sync mode - always remembering the 'on the hour' signal broadcasts. You may also find a way of adjusting the hour to suit if it differs for you once it is synced.
8/21/2019 5:30:11 PM • Citizen Watches • Answered on Aug 21, 2019
Please tell me how old my citizen watch is here are the numbers 5500K05863Ck and 4020529
Best check out the Citizen website, or vintage watch sites. :-)
7/17/2019 1:22:15 AM • Citizen Watches • Answered on Jul 17, 2019
Can I replace the broken crystal on my citizen eco-drive watch myself?
It will be very difficult if you don't have the right tools You would need a hand press of the right size. You would need a tool to open the case back, you would need to know how to remove the crown and stem in order to remove the dial with the movement. It would be also a good idea to have it tested for water resistance and you would need a special aparatus to do that. You may also need to replace the I ring or gasket.
6/28/2019 5:57:07 AM • Citizen Watches • Answered on Jun 28, 2019
Citizen b023 s025508 battery installation
On the bottom of the battery there is a connector with a nub sticking out in one direction only on the bottom and one on the opposite side that juts out and then up. The nub that does NOT stick up should line up with the tiny arrow that is in the battery slot, and you will notice a tiny slot on the opposite side for the other one that juts up. it should stick up and is suppose to touch the back plate of the watch i believe.
5/26/2019 9:45:20 PM • Citizen Watches • Answered on May 26, 2019
How to kick-start a citizen eco drive B 023 watch
i have a citizen eco that i had stored away for too long, the battery was completely dead so i purchased a new one and fixed myself i did take it into a couple of jewellers who wanted to charge me over £100. it wan't too difficult to do.
3/18/2019 5:56:44 PM • Citizen Watches • Answered on Mar 18, 2019
Citizen Silhouette Eco Drive Gold Tone EW9202 96P Watch for Women Logo
1 questions posted
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
View Most Popular
Citizen Watches
  • Citizen Watches
Most Popular Question
resize citizen watch
  • Watches
