20 Most Recent Hitachi DH38MS Jackhammer Questions & Answers
0answers
Hitachi H85
Try just stopping and starting the machine off a while.to see if the hammer appears.
5/3/2014 9:45:25 PM • Hitachi... • Answered on May 03, 2014
0answers
0answers
OIL FOR JACKHAMMERS
There is a sight glass on the side for you to see the oil level. Make sure they are always checked. You can buy the oil at any service center. Hilti makes oil too and can probably be purchased at Home Depots. Also the Home Depots that have tool rental programs would most likely sell the Hitachi oil too.
4/24/2012 6:16:26 AM • Hitachi... • Answered on Apr 24, 2012
2answers
Looking for spec sheet for fiat hitachi ex 135
HITACHI EXCAVATOR MANUAL
12/8/2011 11:48:08 PM • Hitachi... • Answered on Dec 08, 2011
I have a demolition hammer
For most climates a good oil to use is air compressor oil (mineral). Sold at Lowes and many other stores. It has great lubrication properties and can take good amount of heat. In very cold climates where oil could thicken, store hammer indoors to keep warm until ready to use. Good luck
7/1/2011 8:23:31 PM • Hitachi... • Answered on Jul 01, 2011
Hello - I have a Hitachi Demolition Hammer PH-66A.
Hitachi sells a pneumatic oil for use in its air power tools. Your local Hitachi dealer, or any pneumatic dealer will sell the oil. The brand is not as important as using a few drops directly into the air fitting when starting a day of work. If used heavily, oil it again mid way through the working day.
1/26/2010 4:26:24 AM • Hitachi... • Answered on Jan 26, 2010
My dewalt jackhammer starts for 5 seconds then stops but continues making a humming sound. It starts going again if I let go of the trigger and press it again
Maybe a thermal problem in the electronic modul and also control the powercable on a leight tensile load.
8/18/2022 8:58:28 PM • Hammering • Answered on Aug 18, 2022
Kango 950 does not hammer.motor is working, gears are ok. I have dismantled machine and cannot see anything broken
kango 950 was the hammer drill version. Usually when they stopped hammering they were due for a rebuild. These units have a aluminum piston that rides in a steel tube striker. When the 2 rubber piston rings wear out you will get the described problem. The Kango's use a special tan grease so you cannot just yank it apart and replace the 2 rings with o-rings and grease. I had to rebuild 15 900 and 950's because the previous mechanic used the wrong grease. https://project21designs.com/kango-950-parts The link sells grease & rings.
6/3/2022 2:14:01 AM • Hammering • Answered on Jun 03, 2022
Kango 950 motor runs but hammer only engages sometimes
This is an indication that the hammer needs service. When you take the barrel off you will see the striker. There is a piston inside the striker, when the rubber rings on the piston wear out you have the problem you describe. time to replace the motor brushes clean and regressed, make sure to use the correct grease, Check the backlash on ring and pinions. Don't put too much grease on the piston or it will stick and not strike. Good luck I forgot to ask which version. This is for the uk atlas coco, silver with blue or red handle
5/29/2022 2:06:56 AM • Hammering • Answered on May 29, 2022
How much is a kango 426 hammer drill
kango hammer ' Power Tools ' Gumtree Australia Free Local ...
https://www.gumtree.com.au > ... > Power Tools Find kango hammer ads in our Power Tools category. Buy and sell almost anything on Gumtree classifieds. Missing: 426 ‎' Must include: 426 Ads Kango Concrete Tools - View our Concrete Tools Here Ad·https://www.kangotools.com.au/concrete/tools Kango Concrete Tools get the job done. See our range & find your nearest stockist here. Kango has you covered for all things Concreting. View our wide range of tools here. ‎Concrete Tools · ‎Bricklaying Tools · ‎Carbide Technology · ‎Plastering Tools · ‎Drill Bits Kango hammer: Search Result ' eBay Ad·https://www.ebay.com.au/ Free Shipping Available. Buy Top Products on eBay. Money Back Guarantee! Daily Deals. eBay Plus. Returns Made Easy. Huge Selections & Savings. Fast 'N Free Shipping. Buyer Protection Program. World's Largest Selection. Make Money When You Sell. ‎eBay Tuesdays · ‎Sell on eBay · ‎The Latest Tech · ‎Home & Garden · ‎Everyday Essentials
5/5/2022 3:54:10 AM • Hammering • Answered on May 05, 2022
Cant find turmopol oil
10/15/2021 5:29:59 AM • Hammering • Answered on Oct 15, 2021
I am looking for a manual of the detroit demolition breaker 1700W
Contact the manufacturer/distributor to inquire.
3/15/2021 12:35:44 AM • Hammering • Answered on Mar 15, 2021
Where can I get a set of brushes for a kango 950X
Unfortunately, you won't find them - Kango was a great hammer, but the company has been gone for many years and there are no parts available. I would find a local repair shop that may have a different brand brush that is the same or bigger dimensions - by using a piece of 220 grit sandpaper on a hard, flat surface - you can sand them down to the proper size. It will get you out of a bind
3/3/2021 2:37:44 PM • Hammering • Answered on Mar 03, 2021
3answers
Is there any maintenance I can do on a Kango 950 Jack hammer
Ureythn GE00 is madr by Fuchs in Germany - see their website.
Darina is made by Shell - see internet for comparable grease
11/7/2019 2:23:42 AM • Hammering • Answered on Nov 07, 2019
How to troubleshoot the hammer if it vibrates excecively.... ??
no information generic answer --notify the manufacturer or owners manual for assistance
9/13/2019 6:28:41 AM • Hammering • Answered on Sep 13, 2019
Hitachi DH38MS Jackhammer Logo
1 questions posted
Top Hitachi Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
View Most Popular
Hitachi Hammering
  • Hitachi Hammering
Most Popular Question
kind oil
  • Hammering
