20 Most Recent
Timex Indiglo Watch Questions & Answers
I can,t set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a
PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
I have a men's Timex Indiglo watch with day and
Your question brought a smile to my face as I had one also and had the same problem. It took me hours to finally figure out that the stem pulls out to set one thing and pulls out just a little more to set the next.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
How do I change time and date on timex indiglo
How to Set Dial Indiglo Watches - 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
- 2 Pull the knob out from the watch slowly until it clicks into the first position.
- 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
- 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
How to Set Digital Indigo Watches - 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
- 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
- 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
- 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
Read more :
http://www.ehow.com/how_5758168_set-timex-indiglo.html
How to change hours
Timex Watch setting
Make sure you are in the hour/minute/second mode. Press "set" -- the seconds will flash. Then press "mode" again and the right minute number will flash. Press "mode" again and the left minute number will flash. Press "mode" again and the hour will flash. Press "mode" again and the month will flash. Press "mode" again and the date will flash. Any time any groups of these numbers are flashing, you can change the numbers by pressing the "start/stop" button. When you get the numbers you want, press "set" to lock in those numbers.
To change from 12 to 24 hour, get the hour numbers flashing and press
"split/reset." Then press "set" to lock in either 12 or 24 hour time...
How does one replace the battery used to power timex rush T44361
Hi Debra, yours might be similar to my IronMan watch...... 4 small Philips head screws to remove then back comes away to reveal a sticker that has 2 clips either side, use a safety pin point to release the clips and the battery comes off with the sticker! The battery is placed with the total flat side upwards! Hope this helps!
What is Indiglo battery
If you don't know what size battery you need, you can find this information on the back plate of your watch. All Indiglo watches have it stamped there, you may need a magnifying glass to read it though!
Timex Rush Indiglo Watch: shorting the AC pad to the battery
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic. There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery..
