20 Most Recent
Cerruti 1881 Watch Questions & Answers
My cerruti watch always stop at 11:30
It sounds as if the watch has taken a knock, and the hands are no longer properly aligned (that is, no longer at right angles to the stem, so that they rise up and down with respect to the watch face as they rotate, and typically try to 'cross' at a particular time of day).
If this is the case you might be able to see it if you first pull out the winder to the time adjustment position, then look closely across the watch face as you rotate the winder.
If I'm right, it's not a big job to correct it, but not one for the enthusiastic amateur. If you value your watch then take it to a reputable watch repairer.
I hope this helps.
Cerruti watch strap cannot be changed in any watch
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
How to adjust day?
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
I have a Cerrtuit 1881
Hi. I checked around, and found a few jewelers that carry watch bands for your watch.
Here is a list of them. These are all in the Baton Rouge area.
Patton's Fine Jewelry
11740 Coursey Boulevard
Baton Rouge, La
Elgin's Fine Jewelry
9622 Airline Highway
Baton Rouge, La
Anton's fine Jewelry
10675 Coursey Boulevard
Baton Rouge, La
Gary Blanchard Jewelers
5317 Main Street
Zachary, La
Patrick's Fine Jewelry
7179 US Highway 61
Saint Francisville, La
Jack Hood Jewelers Inc.
9265 Florida Boulevard
Baton Rouge, La
Lee Michael's Fine Jewelry
7560 Corporate Bouevard
Baton Rouge, La
K G Custom Jewelry and Expert Watch repair
9564 Florida Boulevard Suite B
Baton Rouge, La
This isn't all of the places in town that would have what you need, but the one's that are on this list all carry and sell watch bands, and should have an acceptable replacement for you.
Good luck, and have a great day !
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
