20 Most Recent Minolta DI-2010F Copier Questions & Answers
Verif pap rec/ouvrir&fermer capot
How about next time you use english, not sure what you are asking about????
4/18/2016 3:35:48 PM • Minolta DI-2010F... • Answered on Apr 18, 2016
DONDE ESTA UBICADO EL FUSOR DE DI2010F
something about a di 2010 fuser????????????????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 8:51:00 PM • Minolta DI-2010F... • Answered on Jan 24, 2016
I'd like to permanently add
3/1/2015 7:59:43 PM • Minolta DI-2010F... • Answered on Mar 01, 2015
How do i clear the
Get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. select image clear. TOTAL CLEAR wipes out a lot more last thing to do, try fax clear but will mess with FAX line setting. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 12:37:44 AM • Minolta DI-2010F... • Answered on Feb 22, 2015
I have an error code
Richard, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/21/2015 5:47:31 AM • Minolta DI-2010F... • Answered on Feb 21, 2015
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
PRINT HEAD failure that is the unit the LASER is in. try open close front door, check connection between print head and image control board if not need a new print head. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 5:20:15 AM • Minolta DI-2010F... • Answered on Feb 19, 2015
Error cord di 450 all error
what is the error code? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/17/2015 12:14:43 AM • Minolta DI-2010F... • Answered on Feb 17, 2015
Soloutions of Code error C0500 in Di 2010f
Sir/Mam, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day!!!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/15/2015 12:58:47 AM • Minolta DI-2010F... • Answered on Feb 15, 2015
Clicking noises coming from konica minolta di2010f copier after changing toner cartridge
Using the correct toner bottle not a EP2010 bottle or biz hub toner bottle, make sure using the correct bottle, if correct bottle turn the machine off remove the toner bottle turn the machine on without the bottle in it. let the machine do its thing when it ask for toner install the bottle correctly. if the nub on the bottle is damaged then get a new one that is what the toner bottle motor uses to turn the bottle if it is damaged its clicking because its trying to turn the bottle. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/15/2015 12:35:16 AM • Minolta DI-2010F... • Answered on Feb 15, 2015
What does code CO500 mean?
Fusing Unit is not working correctly, The fuser is the Hot Part that fuse the toner to the paper Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 11:51:24 PM • Minolta DI-2010F... • Answered on Feb 04, 2015
Di 450 error code c-0210
Right below the drum section is an assemble that has two very fine wires in it. The assemble comes out by pulling it out. have the machine off. When you pull it out you will see to blocks one at each end well those blocks (White Looking) house the connectors for those very thin wires. Several thousand volts travel thru those connectors to the wires to do two things one wire helps transfer the image on to the paper because during the copy/print process the paper goes between both wire and the drum, the second wire prevent the paper from sticking to the drum. After a while with those high voltages going thru those blocks they breakdown and the voltages goes to ground vise the wires causing the machine to issue that code. Might find the those blocks or the whole assy at. the web site below. Open close front door to reset code. Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 11:22:10 PM • Minolta DI-2010F... • Answered on Feb 04, 2015
Wont boot up code 0x00f00201
Recommde that you have a tech come out look at it the abort code that what there are called when they look like that normally have to do with one of the circuit boards in the machine or the firmware the copier is running. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 12:27:59 AM • Minolta DI-2010F... • Answered on Feb 04, 2015
NIC card for Di2010f
If you can find some company that has the kit that includes the NIC card, try contacting Konica Minolta, or local konicaminolta dealership Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 12:24:28 AM • Minolta DI-2010F... • Answered on Feb 04, 2015
Can I scan to my computer from my bizhub di2010f?
YES you can sir/mam assuming you have the scanned kit installed. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 12:21:20 AM • Minolta DI-2010F... • Answered on Feb 04, 2015
Di2010f code C004E
Power unit cooling fan is bad or jammed with dust!. looking at the rear of the machine on the right side lower there is a vent. remove the back panel (will require removing the upper back panel also. There is a filter with that motor. it mite be jammed in the fan clean it and tape it to the metal cover or just remove it then will have to check on every once in while. That fan cools the Power supply inside the machine. Might be burn it out worse case the control board that controls it is bad. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/31/2015 11:33:55 PM • Minolta DI-2010F... • Answered on Jan 31, 2015
Di 450 earer coad c13f8
Print Head error. The print head is what houses the LASER for printing/copying. Open Close front door to reset. IF not replace the Print head. Worse case the image control board is bad. Also check all connections between the print head and the image control board. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/25/2015 9:52:32 PM • Minolta DI-2010F... • Answered on Jan 25, 2015
C-13fa
Sir/Mam, Have C-13F0 in the service manual but no C-13FA . C-13F0 Has to do with the LASER Inside the Print Head which puts the image on the drum. Might want to have that looked at or the Image control board that controls the Print head. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2015 3:16:31 AM • Minolta DI-2010F... • Answered on Jan 23, 2015
C0910 konica di3510
The 2nd Tray Lift motor. Remove draw #2 and check to make sure no paper behind the draw. Secondly REMOVE THE ETRA PAPER IN THE DRAW THE EXTRA SPACE IS NOT FOR SPARE PAPER, it for if you are going to put 11x17 paper in the draw. If these don't work you mite have a burned out 2 tray lift motor. When you close the draw that metal plate at the bottom of the draws goes up Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/21/2015 4:19:34 AM • Minolta DI-2010F... • Answered on Jan 21, 2015
C0500 error code reset
First ensure the right side cover is closed correctly closed also check that the two latches that on the door are not brock especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole.(Once that is done you can only use that paper clip ever again:) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small " ." will appears when it does press 3. Nothing going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. press it then press trouble reset. Once again will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code you messing with is for the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/19/2015 4:38:07 AM • Minolta DI-2010F... • Answered on Jan 19, 2015
Minolta DI-2010F Copier Logo
Popular Tags
52 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
minolta di450 service code reset service
  • Office Equipment & Supplies
