20 Most Recent
Tag Heuer Grand Carrera 17 RS CAV511B Watch Questions & Answers
I have had my Grand Carrera for 7 months and I
This sounds to me as the Oscillating weight is getting loose and touching the movement. There could be a loose screw as well. That's why your watch is stopping (not enough power to fully auto-wind the spring). There is nothing you can do, I'm afraid, but to show watch to the watchmaker for proper inspection. The longer you'll wear it as it is - the more damage will be done.
My watch stops very often its tag heuer grand
It rather depends what you mean by "very often".
An automatic watch will run for 2-3 days before stoping if it is not used.
These watches thrive on being used and are best used every day.
It could be that your watch needs cleaning (I had one that was like that when I bought it and I had it cleaned and it ran for years after that).
I can't manage to adjust
unscrew crown
pull out to postion 1
turn crown to set date
pull out to position 2
turn crown to set time
done!
It won't move winder on Grand Carrera will not move at all
www.bestfixwatch.com/.../Servicing_20Modern_20Automatic_20Watches_2C_20by_20John_20W._20Safranek_20Copyright_2C... - United States -
It has jammed in the spline somehow. This is common though... You will need to take your watch to a Tag Heuer Watch repairer to remedy this particular problem. There is NO Home Fix, as it were. With a watch as good as this it deserves the best treatment.
