20 Most Recent
GE 27938 Cordless Phone Questions & Answers
Message indicator light flashing
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
8/19/2014 2:33:39 AM •
GE 27938...
Answered
on Aug 19, 2014
Blown Resistor 2
tell me how large it is (physical dimensions) and I will get you close to its value.
6/10/2007 1:51:54 PM •
GE 27938...
Answered
on Jun 10, 2007
Blown Resistor
because the phone will not work, first prove that it can. Try this: remove the battery and charge it. Read the voltage on the battery label. Read the voltage on the charger label. If the numbers match, then connect 2 wires to the battery from the charger (use tape) with positive terminals on one wire and negatives the other. after charge...about 2 hours, does the phone work?
6/7/2007 6:40:36 PM •
GE 27938...
Answered
on Jun 07, 2007
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
