20 Most Recent
GE 29439GE2 Corded Phone Questions & Answers
Slow clock
Is there a separate battery for the clock memory? If so I would try changing that. Otherwise the clock is probably busted. Digital clocks would not normally loose more than a few seconds a year. If the clocks crystal oscillator broke it may cause this. That could happen if the crystal was not glued down or came loose.
GE 2-9439 Phone i need the manual to store numbers
1. Press the button you want to program
2. Press the Store button (red light will illuminate)
3. Enter the phone number
4. Press Store again (red light will flash)
5. Press the button you want to program (again)
GE 29439GE2
Copy directly from the manual:
TONE/PULSE
Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which
type of service you have (pulse or tone), check with your phone company.
To program TONE/PULSE for all 3 lines:
1. Press STORE/IN
2. Press 0 for PULSE or Press 1 for TONE
3. Press STORE/IN
4. Press TONE
To program TONE/PULSE for each line individually:
1. Press STORE/IN
3. Press STORE/IN
4. Press LOWER
5. Press line number (1, 2, or 3)
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
