20 Most Recent
GE 27928GE2 Cordless Phone Questions & Answers
Message box full-cannot cleat
On most GE 27***GE-series phones the DELETE key on the base is to the left of the down arrow for MESSAGES/CID keys; the DELETE button is the button on the far left on the bottom row of tiny keys.
Press the button briefly during play-back to delete the message being played, or press and hold the delete button for a full 2 to 4 seconds to clear ALL messages.
Memory Full - model #27958 - GE 2.4GHz
if the play button on the base no longer works - on the handset just above the 3 is a silver answer/format button . . . press it for about 1.5 seconds and then press the 2
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
