20 Most Recent Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer Questions & Answers
0answers
0answers
How to install wiring
Start at the transducer, mount it then pull the transducer wiring forward using a wire snake. At the same time pull forward 14ga wire to attach to your power leads. on most boats I've done this process takes from 90 minutes to 3 hours. The transducer and head unit are easy to put on. Getting wire from point A to point B is the time consuming part. Once you have your wires pulled forward route them to your head unit at your console. Drilling of access holes may be required. Connect power, plug in the transducer line. Black to negative at the battery, red to positive, don't forget to put in the in line fuse included in your box. Good luck.
5/27/2015 12:25:30 PM • Lowrance Elite-7... • Answered on May 27, 2015
2answers
Have bought a new lowrance elite 7 have trouble locking satelite open boat with fibreglass hard top ?
Since you just purchased it contact the seller, it should be covered under warranty.
3/2/2015 8:54:32 PM • Lowrance Elite-7... • Answered on Mar 02, 2015
How do i do my updates for my elite7 hdi from my computer and getting them to my combo . my computer wont open the download through adobe.
Assuming you are using Navionics, plug your charts memory into your computer log into Navionics and follow the prompts for update
11/26/2014 8:58:00 AM • Lowrance Elite-7... • Answered on Nov 26, 2014
How to change language to enlish
Hi Kane, I have this manual for you on how to set up setting up Language on page 42 to 43. Hope it helps. http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf
4/25/2014 10:06:11 AM • Lowrance Elite-7... • Answered on Apr 25, 2014
Gps is on north to the top.how do i change it to
Go into your settkngs function. Change the view from North up to heading up.
1/11/2014 5:30:51 AM • Lowrance Elite-7... • Answered on Jan 11, 2014
Lowrance Mark 5x DSi won't power up
If your Lowrance Mark 5x DSi won't power up, there are a few things you can try:
  1. Check the power source: Make sure the unit is properly connected to a power source that is providing the correct voltage. Check the power cable and connections for any damage or loose connections.
  2. Check the fuses: The Mark 5x DSi has a fuse on the back of the unit. Check to make sure it hasn't blown. If it has, replace it with a new fuse of the same amperage.
  3. Reset the unit: Try resetting the unit by pressing and holding the power button for 10-15 seconds. This will force the unit to shut down and reset.
  4. Check for water damage: If the unit has been exposed to water or moisture, it may be damaged. Check for any signs of water damage, such as corrosion on the connectors or internal components.
If none of these solutions work, it may be necessary to take the unit to a professional for repair or replacement.
2/23/2023 5:35:57 PM • Lowrance Boating • Answered on Feb 23, 2023
I have a Lowrance Hook 7 fish finder and recently purchased a minn kota trolling motor with universal sonar2. Which adapter cableMKR US2-10 ? do I need.
To connect your Lowrance Hook 7 fish finder to your Minn Kota trolling motor with Universal Sonar 2, you will need the MKR-US2-10 adapter cable. This cable is specifically designed for connecting Lowrance and other fish finders to Minn Kota motors with Universal Sonar 2 technology
2/23/2023 4:59:44 PM • Lowrance Boating • Answered on Feb 23, 2023
How to get out of simulator mode lowrance hook2 4x fishfinder
To exit Simulator mode on a Lowrance Hook2 4x Fishfinder, you will need to navigate through the device's menu settings. The exact steps may vary depending on the specific version of the Hook2 4x, but in general, you will need to:
  1. Press the power button to turn on the device
  2. Press the menu button
  3. Use the arrow buttons to navigate to the "System" menu
  4. Use the arrow buttons to select "Simulator" and press enter
  5. Use the arrow buttons to select "Off" and press enter
It's important to refer to the user manual of your Hook2 4x for the specific instructions on exiting simulator mode as the exact steps may vary depending on the version of the Hook2 4x you have.
1/20/2023 10:23:34 AM • Lowrance Boating • Answered on Jan 20, 2023
My Lowrance 525C Fish Finder comes on to Lowrance screen but does nothing when I mash any of the buttons. Eventually turns off by itself.
Question edited for clarity. Make sure you got the correct transducer Your model comes in single frequency and dual frequency. Make sure the connection on the back of the unit is good and you have no corroded or missing pins. Make sure the software is up to date. Lowrance LMS-525C DF Fish Finder Parts Product Description: Designed for salt water or downrigger tracking, this dual-frequency sonar/GPS chartplotter provides additional 50 kHz readings, in addition to a high-res 480 x 480 display on a 5" screen and many professional features. * Dual-frequency 50/200 kHz * Precision 12-parallel channel external GPS+WAAS receiver * Lowrance radar compatible * LowranceNET® networking (NMEA 2000® certification pending) * High-speed ethernet connection links multiple Lowrance display units and modules to operate independently on shared network data, including sonar 200 khz transducer PDRT-WBL Part #106-89 Shoot-thru-hull mount, 20 degree pod type with remote temperature (200 kHz). (20 ft cable) Dual Frequency Transducer HP-DFBL260 Part #106-82 Thru-hull-mount, dual frequency bronze housing, high-power multiple element (50 kHz 19 degree & 200 kHz 6 degree). HST-DFSBL Part #106-77 Transom-mount, dual frequency skimmer with built-in temperature sensor. (25 feet of cable) https://www.google.com/search?q=lowrance+lms-525c+df+software+update ..
6/2/2022 1:45:06 AM • Lowrance Boating • Answered on Jun 02, 2022
Lowrance LMF-400 Update LUF File
5/17/2022 4:41:41 AM • Lowrance Boating • Answered on May 17, 2022
Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer Logo
20 questions posted
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
navigate back waypoint
  • Boating
