20 Most Recent
GE 29868GE1 Digital Answering Machine Questions & Answers
Manual
http://157.254.235.130/public/IB29868R1.pdf
Have problem changing auto answer to longer than 3
Press and hold the SET button to enter the change mode. The unit announces the current time and day. Press SET repeatedly until the unit announces the rings to answer. Press and release NEXT or PREVIOUS until the unit announces the correct number of rings for the answerer to pick up. Once the rings to answer is set, press SET to enter the incoming message length menu.If you need a manual, you can download one
here.
How to change the message
Hold down the GREETING button. Record the new message at the beep. Release the button when done.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/29868_DOM_EN_AN_IB.pdf
For answereing machine no 2-9805A
While playing the message, press the ERASE button.
Full details are on page 11 of the manual at
Need to put a greeting on the answering machine
Hold down the GREETING button. Record your greeting at the beep. Release the button when done.
Full instructions are on page 6 of the manual at
How do you change the greeting message
Press and hold the GREETING button. Record your greeting at the beep. Release the button when done.
How do i change the
Press and hold the SET button to enter the change mode. Full instructions are in the "Changing the Settings" section beginning on page 7 of the manual at
How do I change the date and time?
Press and hold the SET button to enter the change mode. The full instructions are in the "Changing the Settings" section beginning on page 7 of the manual at
http://www.home-electronics.net/ge/pc/IB/29869GE2_IB.pdf
How do I set voice
Hello there, to add a time and day stamp on your messages on your answering machine first you have to set the date and time on the unit. Once the date and time has been set the voice time day stamp should automatically be a part of each message which is left on the machine. to get directions on how to set the time and date follow the instructions on page 9 in the manual below.
http://157.254.235.130/public/15401590R1.pdf
Hope this solution has been helpful?
Thank you for visiting FixYa.
