20 Most Recent Sharp AR-M160 Black and White Copier Questions & Answers
"Press # - Interrupt - C - Interrupt -14 - Start key" Thermistor open
The thermistor is open. The fusing unit is not installed.
Sharp AR-M160... | Answered on Apr 02, 2017
Fixing unit is bad the very hot part of the machine is bad replace the fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp AR-M160... | Answered on Feb 01, 2016
EEPROM error , need to order a new EEPROM from Japan, or a mainbord issue
need to replace , no reset available
Sharp AR-M160... | Answered on Nov 04, 2014
replace toner , just test toner motor first , and test developer unit is turning , and clean developer sensor,
Sharp AR-M160... | Answered on Aug 25, 2014
You can sell it safely, copiers have no hard drives. No data is saved on it permanently.
Sharp AR-M160... | Answered on Apr 29, 2014
Please replace all faulty consumables.
Sharp AR-M160... | Answered on Jan 07, 2014
"Press # - Interrupt - C - Interrupt -14 - Start key Thermistor open
Sharp AR-M160... | Answered on Dec 03, 2013
error is sometimes a way for the machine to go into safe-mode when there is power fluctuations , or a problem with the machines thermistor or thermostat
Sharp AR-M160... | Answered on Oct 09, 2013
specify the operating system
system bit rating
Most printers come with a cd that you have to put on your computer. The cd's have to drivers on. If you don't have the printer cd any longer, maybe contact the manufacturer or any electrical store, they may be able to order one for you.
Sharp AR-M160... | Answered on Sep 14, 2012
There is need to solve the low current problem by simply rectifying it frfom the power supply.
enter simulation (use SIM14) 'C' 'auto' 'C' 14 copy key
Sharp AR-M160... | Answered on Oct 21, 2011
it seems to be the problem of the drum.how many copies has it yielded .call a rep and change it
Sharp AR-M160... | Answered on Aug 20, 2011
Sharp AR-M160 Black and White Copier Logo
46 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
arm160
  • Office Equipment & Supplies
