20 Most Recent
Dell M109S DLP Projector Questions & Answers
The screen in green?
Sounds like a loose or broken vga cable. Push it in all the way. If it's still greenish try replacing the vga cable to the projector.
P.S. Is it just green in one spot or the whole image?
The Menu bar was locked
All u need is to read user manual that says press the Menu key for 15 sec and Menu bar wil be unlocked.
Pink blue tint on display
Hello Adam, try replacing your signal cable. the signal cable has 3 color wires, 1 for red, 1 for blue, and 1 for green, the green wire is cut off, due to stress of twisting and pulling. find one on ebay. thats it.
It is projecting a yellow
Hello Jessica Hi, If your projector image is complete just kinda yellow, your problem is the signal cable, basically these are the three primary colors, red, green and blue, Now let us say you remove the blue, it will produce what color? yes yellow. so the blue wire inside the signal cable is cut off. find a replacement signal cable for your projector. Try ebay. take note of the model of your projector. thats it.
