20 Most Recent GE APN08AA Portable Room Air Conditioner Questions & Answers
3answers
E4 error on my ge air conditioner THE FIX IS EASY
HOW LONG IS DEFROST
1/10/2019 3:47:32 AM • GE APN08AA... • Answered on Jan 10, 2019
HOW TO CLEAN THE DRAIN PAN ON A GE WINDOW AIR CONDITIONER
you have to remove it from wall & wash coil with hose add a little bleach to pan.
9/5/2015 9:18:02 PM • GE APN08AA... • Answered on Sep 05, 2015
Why would a portable air conditioner only blow cold air for a few seconds and then only blow warm air? Compressor seems to shut down.
compressor shuting of on thermostat or safety. getting to hot or drawing to many amps.
8/13/2015 11:34:32 PM • GE APN08AA... • Answered on Aug 13, 2015
0answers
Leaking water
Be the first to answer 7/17/2013 3:01:50 AM • GE APN08AA... • Posted on Jul 17, 2013Be the first to answer
Compressure works then stop and blows hot air
May be the compressor in Portable Room Air Conditioner is not getting enough power or voltage to run for long hours. Please get check Air Conditioner by any technician.
6/21/2012 5:50:14 AM • GE APN08AA... • Answered on Jun 21, 2012
My portable ge air contioner
The reason you are blowing fuses is 'high amp draw,' which is most always caused by a 'electrical short,' and the most common things to cause such a short are the 'compressor and fan motor(s).
I would say you need a serviceperson to determine exactly what is causing your short.
6/9/2011 12:48:13 PM • GE APN08AA... • Answered on Jun 09, 2011
My GE portable air conditioner is not cooling but fan works
I think it's becuase the water tank on the side is full and when that happens it turns off. Empty the water...and then reach your hand in and find a small reset button press it and then but the chamber back in and see if that works. I had that problem and same code
6/23/2009 12:21:27 AM • GE APN08AA... • Answered on Jun 23, 2009
2answers
GE window air conditioner showing error code E8
Shery ck here... https://www.youtube.com/watch?v=K_WWBNEuSnU also clean the unit... unplug.. spray hose thru the vanes/coils outside/back side to remove dust and dirt from the unit. Let sit for 15-20 minutes before pluging back in. https://www.youtube.com/results?search_query=clean+window+ac+unit+without+removing Best to you.
12/18/2023 5:17:56 AM • GE Heating &... • Answered on Dec 18, 2023
GE SV850 range hood stopped working
Transformers do usually feel warm. If it is very hot it has likely failed internally. Check for output voltages with a digital multimeter.
7/2/2023 11:28:19 PM • GE Heating &... • Answered on Jul 02, 2023
I have GE gas oven, getting error code F97
Impossible to say. There are a lot of variables here. Which country, and which model. Even different cities would charge different prices. It is a gas appliance, so you can't work on it yourself. Just for information, we are Fixya dot com, we aren't GE, we don't do pricing for them. The only way is to ask a local appliance shop. A good way is to ask for a recommendation on a local Facebook group where you live.
5/13/2023 3:09:56 AM • GE Heating &... • Answered on May 13, 2023
I have a GE remote control universal remote and it is number 24922cl57252 and I want to pair that with my air conditioner which is a solace air portable air conditioner and heater how do I do it
Here are the steps to program your GE universal remote (model number 24922cl57252) to work with your Solace Air portable air conditioner:
  1. Turn on your Solace Air portable air conditioner.
  2. Press and hold the "Setup" button on your GE universal remote until the red indicator light stays on.
  3. Enter the code "991" using the number buttons on your GE remote. The red indicator light will turn off.
  4. Press the "Power" button on the GE remote.
  5. Press the "Up" or "Down" button to try and turn the air conditioner off. If the air conditioner turns off, press the "Setup" button to lock in the code.
If the air conditioner does not turn off, repeat steps 2-5 with a different code from the list below until the air conditioner turns off: Solace Air Portable Air Conditioner Codes: 0277, 0363, 0364, 0365, 0403, 0454, 0455, 0456, 0457, 0474, 0475, 0494, 0495, 0496, 0497 I hope this helps!
2/24/2023 10:26:45 PM • GE Heating &... • Answered on Feb 24, 2023
PTAC Blows Cold Air in Heating Mode when it reaches -3F less than the Set Value on the Thermostat - Model: AZ65H15DABW6
It sounds like your PTAC (packaged terminal air conditioner) unit is malfunctioning. When the thermostat is set to heating mode, the PTAC should be blowing warm air, not cold air. There are a few possible causes for this issue:
  1. The PTAC may be low on refrigerant. If the unit is low on refrigerant, it may not be able to properly heat the air.
  2. The PTAC's reversing valve may be stuck in the cooling position. The reversing valve is responsible for switching the flow of refrigerant between heating and cooling mode. If it is stuck in the cooling position, the PTAC will blow cold air even when the thermostat is set to heating mode.
  3. The PTAC's heating element may be malfunctioning. If the heating element is not functioning properly, the PTAC will not be able to heat the air.
I recommend contacting a trained HVAC technician to diagnose and fix the issue with your PTAC. They will be able to determine the cause of the problem and repair it properly.
1/6/2023 8:23:16 PM • GE Heating &... • Answered on Jan 06, 2023
PTAC fan stalls when heat pump stops
Sounds like a bad motor module.
12/11/2022 3:01:46 AM • GE Heating &... • Answered on Dec 11, 2022
Why won't the heater of ge zoneline 2100 stay on
Hi, If the heater goes off right away when you start it, please check the corresponding fuse within your fusebox. Also, checking for any warn wires would be good as well. I would also test other outlets verify that it's not your current power source that's the issue. Thank you.
11/3/2022 12:49:49 AM • GE Heating &... • Answered on Nov 03, 2022
GE APN08AA Portable Room Air Conditioner Logo
Popular Tags
11 questions posted
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • GE Heating & Cooling
Most Popular Question
ge portable air conditioner not cooling
  • Heating & Cooling
