Start with tablet off. Hold power and volume up. You should boot into safe/repair mode. Try some of the options in there to get your tablet going again.
I tried the same thing I had to go under settings and manually reset it. It is settings, About device and Factory Reset and back up section. I hope this was helpful for you.
go to you tube type your question in and you will get the help you need in the form of a video which you can pause and follow it step by step . hope this helps you .
You can try a factory reset on the tablet. Hold the volume down button and press the power button. This should bring up a system menu that should have an option to perform a factory reset on the tablet.
If it just stopped charging and you have tried other chrgers, then the probable cause would be the battery for the tablet has failed. This is fairly common and would require disassembly of the tablet and replacement of the battery to fix.
It would not be easy to explain by this message; however, you need to go into your settings and add your tablet ("PAIR" it with your computer)
http://visual-land.com/downloads/prestige7ljb_manual.pdf . Go to page 21 in the manual. Make sure you download the manual so you have it for future use
