20 Most Recent GE Zoneline AZ55H15D Air Conditioner Questions & Answers
Removed from sleeve for cleaning Model # AZ52H15DABM1 GE.Reinstalled,turned on , worked fine. Now when turned off,blower fan turns on automatically .
on some models a "vent switch" located on the out side of the case may get flipped and cause this.
3/3/2012 6:07:22 AM • GE Zoneline... • Answered on Mar 03, 2012
I have panasonic 1.5 window
Check the coolant. It must be depleted. Requires a refill.
5/28/2011 11:40:08 AM • GE Zoneline... • Answered on May 28, 2011
2answers
GE window air conditioner showing error code E8
Shery ck here... https://www.youtube.com/watch?v=K_WWBNEuSnU also clean the unit... unplug.. spray hose thru the vanes/coils outside/back side to remove dust and dirt from the unit. Let sit for 15-20 minutes before pluging back in. https://www.youtube.com/results?search_query=clean+window+ac+unit+without+removing Best to you.
12/18/2023 5:17:56 AM • GE Heating &... • Answered on Dec 18, 2023
GE SV850 range hood stopped working
Transformers do usually feel warm. If it is very hot it has likely failed internally. Check for output voltages with a digital multimeter.
7/2/2023 11:28:19 PM • GE Heating &... • Answered on Jul 02, 2023
I have GE gas oven, getting error code F97
Impossible to say. There are a lot of variables here. Which country, and which model. Even different cities would charge different prices. It is a gas appliance, so you can't work on it yourself. Just for information, we are Fixya dot com, we aren't GE, we don't do pricing for them. The only way is to ask a local appliance shop. A good way is to ask for a recommendation on a local Facebook group where you live.
5/13/2023 3:09:56 AM • GE Heating &... • Answered on May 13, 2023
I have a GE remote control universal remote and it is number 24922cl57252 and I want to pair that with my air conditioner which is a solace air portable air conditioner and heater how do I do it
Here are the steps to program your GE universal remote (model number 24922cl57252) to work with your Solace Air portable air conditioner:
  1. Turn on your Solace Air portable air conditioner.
  2. Press and hold the "Setup" button on your GE universal remote until the red indicator light stays on.
  3. Enter the code "991" using the number buttons on your GE remote. The red indicator light will turn off.
  4. Press the "Power" button on the GE remote.
  5. Press the "Up" or "Down" button to try and turn the air conditioner off. If the air conditioner turns off, press the "Setup" button to lock in the code.
If the air conditioner does not turn off, repeat steps 2-5 with a different code from the list below until the air conditioner turns off: Solace Air Portable Air Conditioner Codes: 0277, 0363, 0364, 0365, 0403, 0454, 0455, 0456, 0457, 0474, 0475, 0494, 0495, 0496, 0497 I hope this helps!
2/24/2023 10:26:45 PM • GE Heating &... • Answered on Feb 24, 2023
PTAC Blows Cold Air in Heating Mode when it reaches -3F less than the Set Value on the Thermostat - Model: AZ65H15DABW6
It sounds like your PTAC (packaged terminal air conditioner) unit is malfunctioning. When the thermostat is set to heating mode, the PTAC should be blowing warm air, not cold air. There are a few possible causes for this issue:
  1. The PTAC may be low on refrigerant. If the unit is low on refrigerant, it may not be able to properly heat the air.
  2. The PTAC's reversing valve may be stuck in the cooling position. The reversing valve is responsible for switching the flow of refrigerant between heating and cooling mode. If it is stuck in the cooling position, the PTAC will blow cold air even when the thermostat is set to heating mode.
  3. The PTAC's heating element may be malfunctioning. If the heating element is not functioning properly, the PTAC will not be able to heat the air.
I recommend contacting a trained HVAC technician to diagnose and fix the issue with your PTAC. They will be able to determine the cause of the problem and repair it properly.
1/6/2023 8:23:16 PM • GE Heating &... • Answered on Jan 06, 2023
PTAC fan stalls when heat pump stops
Sounds like a bad motor module.
12/11/2022 3:01:46 AM • GE Heating &... • Answered on Dec 11, 2022
Why won't the heater of ge zoneline 2100 stay on
Hi, If the heater goes off right away when you start it, please check the corresponding fuse within your fusebox. Also, checking for any warn wires would be good as well. I would also test other outlets verify that it's not your current power source that's the issue. Thank you.
11/3/2022 12:49:49 AM • GE Heating &... • Answered on Nov 03, 2022
2answers
Why will my GE Zoneline 2100 work on high cool and high heat settings, but on low cool and low heat the fan won't run.
I don’t believe the remote tstat accepts those functions to change the fan speed versus using the on board controls. Try to change the fan speed while using the on board controls and when you have that setup then go back and change it to remote tstat setting.
8/21/2022 7:49:26 AM • GE Heating &... • Answered on Aug 21, 2022
What does a code E4 mean on my GE window air unit?
https://www.reviewhomewarranties.com/home-maintenance/hvac/fixing-e4-error-on-air-conditioner/
7/30/2022 9:24:11 PM • GE Heating &... • Answered on Jul 30, 2022
GE air conditioner jumps to 86 on the display
bad temp sensor
5/19/2022 3:57:38 AM • GE Heating &... • Answered on May 19, 2022
I have a GE refrigerator model number GTS18GTHSRWW it has stopped cooling and the freezer has stopped also I opened the panel in the back and found three green and yellow wires not connected.
Green and Yellow are earths, so those aren't the issue. You need a service call. The most likely reason is that you have a refrigerant gas leak.
1/12/2022 4:33:00 AM • GE Heating &... • Answered on Jan 12, 2022
GE profile microwave convection does not reach temperature
Needs a new thermostat or heat sensor. Take it in for professional service.
12/31/2021 3:37:43 AM • GE Heating &... • Answered on Dec 31, 2021
GE Zoneline AZ55H15D Air Conditioner Logo
3 questions posted
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • GE Heating & Cooling
Most Popular Question
removed from sleeve cleaning model
  • Heating & Cooling
