20 Most Recent GE 24 in. GSD5950 Built-in Dishwasher Questions & Answers
I have a GE dishwasher model GLD4908T10BB and the light is on for rinse only but does not turn on and will not let me change the settings?
Try a power disconnect from the mains for 5 minutes and then plug it back in. It that doesn't fix it, the problem will be the main control board. Many parts are obsolete. https://www.google.com/search?q=GLD4908T10BB ..
3/14/2024 10:15:10 PM • GE Dishwashers • Answered on Mar 14, 2024
Ge dishwasher lower rack doesn't get clean
I have spent all my career in the catering and food industry with dishwashers of all shapes and sizes.The usual reason for this can be two fold.First make sure that the bottom spray arm spins freely. For various reasons they can stick and that means the spray only hits one place. If you spin it, it should spin at least 2 revolutions. Even if it does....Remove the bottom spray arm. The thing that makes it spin is the angled jets in either end. They will often block with debris, and the worst is lemon pips and cocktail sticks, even fluff. No one knows how fluff gets in there, but it does. At my last job at a VERY busy airport lounge putting literally hundreds of baskets through a day, the two filters had to be de-fluffed every day. The problem at home is that the fluff solidifies between uses. So look at those end two jets, poke with something and put water in from the jet end rinsing to the big hole in the centre. Put the plug in the sink so you can see what comes out. The turn the arm over and force a good jet of water into the big centre hole and it should show as a good jet at the ends. Then put the arm back and make sure it spins.Your machine has a strange item called a 4 port diverter valve. This part concerns me a bit as it appears that it may be supposed to move or at least has to be in the correct orientation. Some items like this have a rubber flap that really does divert the flow. Once gain, some type of debris can ruin its function. It looks easy enough to remove.504 - Diagram Number FOUR PORT DIVERTER AND PLUG ASSEMBLY WD19X26398https://www.geapplianceparts.com/store/parts/assembly/PDT715SYN3FSAnother trick is to whip the door open mid wash if it doesn't have a safety lock and see what the arm is doing and if it is spraying well.I hope this is more use than our friend Umar Waheed! We are getting a lot of the AI Chat GPT4 Points Jockeys! Usually after 40 to 100 answers, they ask "How do I cash out my points" :>D..
2/20/2024 7:24:14 PM • GE Dishwashers • Answered on Feb 20, 2024
GE dishwasher gives H2O code but it gets water!?!??!
kindly cehck the water inket valve Sometimes, the valve might not open fully during a cycle, causing water flow issues or it may be clogged
8/15/2023 8:36:20 AM • GE Dishwashers • Answered on Aug 15, 2023
GE Profile dishwasher gave a code of 888. What
Make sure the hot water is on
4/29/2023 4:09:04 PM • GE Dishwashers • Answered on Apr 29, 2023
Why is my GE dishwasher drain solenoid continuously burning up?
There could be a few reasons why your GE dishwasher drain solenoid keeps burning up:
  1. Overloading the dishwasher: Overloading the dishwasher can cause the motor to work harder, which in turn can cause the drain solenoid to burn out.
  2. Improper installation: If the drain solenoid is not installed correctly or there is a wiring issue, this can cause the solenoid to burn out.
  3. Clogs or blockages: If there are clogs or blockages in the dishwasher's drain line or garbage disposal, this can cause the motor to work harder and burn out the drain solenoid.
  4. Electrical issues: If there are electrical issues with the dishwasher, such as a short circuit, this can cause the solenoid to burn out.
To troubleshoot the issue, you may want to start by checking the dishwasher's drain line and garbage disposal for any clogs or blockages. You can also check the dishwasher's installation and wiring to ensure everything is properly connected. If the issue persists, you may need to consult a professional appliance repair technician to diagnose and fix the problem.
2/24/2023 6:39:12 AM • GE Dishwashers • Answered on Feb 24, 2023
2answers
GLD2800V00WW GE dishwasher - doesn't stop washing when door is opened.
The OP Michelle writes with the FIX! Well done. I was able to repair by doing the following: Removed the inner cover and the cover over the interlock switch. The peg and spring between the interlock switch and the other switch (?) flew out. The peg slides in-between two white plastic "legs" that seemed bent. Tried to straighten them, re-inserted the peg and spring. Removed the interlock switch, checked connection was firm and reinserted. Made sure peg slides up and down. Closed everything up and voila! The dishwasher stops when door is opened. No new parts needed! ..
1/1/2023 4:50:08 AM • GE Dishwashers • Answered on Jan 01, 2023
6answers
GE Dishwasher makes loud banging noise
Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
12/29/2022 1:16:28 AM • GE Dishwashers • Answered on Dec 29, 2022
GE dishwasher profile quiet power 6 start/reset button not working.
These buttons suck and the software even more.. there should be an unlock button for this dishwasher if it locks up
12/7/2022 3:59:33 AM • GE Dishwashers • Answered on Dec 07, 2022
GE GSD4020 is leaking from the bottom, how can I fix it?
Uploading pictures is easy. Click the Photos icon and follow the prompts. There are videos here regarding leaks. https://www.google.com/search?q=GE+GSD4020+is+leaking+from+the+bottom .. efined-undefined-0.jpg" alt="9EE32182-E376-4B35-AC45-286B9A370F39-undefined-undefined-0.jpg">
11/4/2022 6:13:38 PM • GE Dishwashers • Answered on Nov 04, 2022
GE Dishwasher GCD4800LSS water level or float switch?
Thanks your question. please see this video
10/9/2022 5:57:10 AM • GE Dishwashers • Answered on Oct 09, 2022
2answers
GE Profile Dishwasher about 7 years old.
The washer doesn't pump water in--plumbing water pressure forces it in when the water inlet solenoid opens the valve. Check the water inlet solenoid--they are a common failure point. Look under the front of the washer behind the panel to find it--just trace the water inlet line. It connects directly to it. The valve can be stuck shut or, more commonly, the plastic coil form of the solenoid disintegrates. In any case, just replace it. Don't forget to shut off the water supply valve under the sink before you start work. Hope this helps!
8/17/2022 3:20:26 AM • GE Dishwashers • Answered on Aug 17, 2022
GE dishwasher rinses, but won't fill for wash cycle
It could be a failing water inlet valve or the main control board. If it does it every time you try, it is not the water inlet, it is the Control Board. Unfortunately both parts are obsolete. Time for a new one or search for parts in stock somewhere. https://www.partselect.ca/Models/GDT545PSJ0SS/Sections/Body-Parts/?ModelID=6882101&ModelNum=GDT545PSJ0SS&mfgModelNum=&ManufactureID=2&Selected=35592F79C4D18354271BEB350E3C0B86DA4AF3F2&Position=1&mfg=GE&Type=Dishwasher&Mark=1 https://www.google.com/search?q=GE+dishwasher+GDT545PSJ0SS+parts ..
8/14/2022 11:37:02 PM • GE Dishwashers • Answered on Aug 14, 2022
Zbd6900p1011 GE Monogram dishwasher leaking from bottom of the door. What can I do? Can i fix it myself?
Check the dishwasher to door seal for any defects or debris that maybe interfering with the maintaining of a proper seal.
8/13/2022 6:01:37 PM • GE Dishwashers • Answered on Aug 13, 2022
2answers
GE Potscrubber 640 Dishwasher. How long does it take before the water starts running in the dishwasher? Can hear the motor, but not any water.
Check under the sink and make sure it is not shut off there. If there is water pressure to the unit then you could have a sticky inlet valve, no power to solenoid on that valve or a bad solenoid, a sticky overfill valve or a bad control board.
3/23/2022 1:48:54 AM • GE Dishwashers • Answered on Mar 23, 2022
GE triton quiet power 2 dishwasher, flooded the kitchen mid-cycle and isn't draining. What do I do?
try using a tile grout sponge avail at hd or Lowe's
3/21/2022 12:14:54 AM • GE Dishwashers • Answered on Mar 21, 2022
I have a GE (GSC3200Z00BL) that leaks while running
The pump or connecting hoses are leaking.
3/12/2022 5:26:50 PM • GE Dishwashers • Answered on Mar 12, 2022
GE 24 in. GSD5950 Built-in Dishwasher Logo
Popular Tags
0 questions posted
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
cleaned filters 12 year olf ge
  • Dishwashers
