20 Most Recent
AT&T ATT AT3211-2 DECT 6.0 Digital Dual-Handset Phone With Caller ID/Call Waiting, Black/Silver Questions & Answers
BLOCK A PHONE NUMBER
HiPUK code is called as PERSONNAL UNBLOCKING KEY.Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK codeDONOT enter the PUK code several times wrongly,It will block your sim card permanently.This PUK code is FREE. You no need to pay any sum to get the PUK codeThank You.
Can I buy a replacement hand set for an AT&T cordless model #SL82218
Yes, a "google search" for SL82218 returns quite a few loose handsets being sold on eBay. But then you'll have to deregister
the new handset from its old base and re-register it to your base...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
if your system was fully populated you will have to clear all the
handsets from the base and re-register them ( it is the only way
to 'rescue' the place occupied by the lost handset ). The manual
describes how to "Register a HS" in Appendix C, pages 60-61
and it is available from:
www.manualslib.com
Good luck !
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit
http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM •
Lands Phones
Answered
on Mar 21, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=?
TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM •
Lands Phones
Answered
on Feb 05, 2024
