20 Most Recent GE Profile PDW8480JSS Built-in Dishwasher Questions & Answers
2answers
Our PDW8280J03SS caught fire and brunt out at the
You should tell the manufacturer as it is obviously a generic problem if there have been recalls. Ask them what they are prepared to do for you. You must put it in writing, no use using the phone.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
3/2/2022 2:12:21 PM • GE Profile... • Answered on Mar 02, 2022
2answers
We have had this dishwasher for approximately 2
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
12/11/2014 4:37:54 PM • GE Profile... • Answered on Dec 11, 2014
2answers
Dishwasher will not drain. We
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
4/30/2011 11:24:29 PM • GE Profile... • Answered on Apr 30, 2011
Water is coming from the bottom
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
3/24/2011 3:47:57 AM • GE Profile... • Answered on Mar 24, 2011
Dishes are not getting cleaned, covered in ??
heatman101
2/24/2011 12:55:40 AM • GE Profile... • Answered on Feb 24, 2011
The glassware is not being cleaned well. It is
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
2/20/2011 7:33:29 PM • GE Profile... • Answered on Feb 20, 2011
The soap is not coming
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
2/14/2011 1:08:08 AM • GE Profile... • Answered on Feb 14, 2011
Will not start. Shows 1h on time panel. Reset does
The 1 H is not a fault code it is the delay time of one hour.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
8/15/2010 1:20:35 PM • GE Profile... • Answered on Aug 15, 2010
Smoking not electric smell but different odor
You should call a trained serviceman. You don't want to end up with a fire. If you want you can also look at the element it should be a circle of metal at the bottom of the dishwasher (It is suspended by hangers of some type so it doesn't touch the plastic sides of the dishwasher). If you have hard water buildup on it it may look like there is a smooth cement-like coating on it. That can smell when the element heats up. Also, does it smoke and/or smell if you don't allow the dry cycle to run? If you don't have the money now to have a serviceman look at it, you probably should shut the power off to it and wash your dishes by hand till you have the money.
6/13/2010 8:20:39 PM • GE Profile... • Answered on Jun 13, 2010
DIshwasher won't start. Start/Reset button
Hi
It seems you have some dirt or debris stuck in the little pump that pumps the water out of the dishwasher. To get at the pump you will remove the lower front panel and follow the drain line down toward the floor,there u will see that the drain line is connected to a small pump.You have to disconnect the drain line and remvove the two screws that hold the pump to the frame. look in the pump and you will see your problem debris,sometimes a chunk of glass or bone can be stuck.Remove it and put everything back in order and your dishwasher will start functioning.
However if the above steps doesnt get your dihwasher run I can suspect there's a fault with the main control board.
However you can try a reset on it to see if it will recover.
Switch the machine off.
Switch it on and don't wait for any lights, as soon as you press the on button, press the programme button 4 times within 3 seconds.
You have to be extremely quick to do this.
If successful the two end lights will come on flashing.
Press the programme button once, the first light will go out.
Switch off and wait 20 seconds, switch on, as the lights come on, switch off again. Wait another 20 seconds. Switch on and you should be able to select a program.
please let us know if this has solved your problem.
do let us know for further query
thankyou for contacting fixya.com
8/12/2009 2:52:10 PM • GE Profile... • Answered on Aug 12, 2009
Leak from dishwasehr drain
Creilly, there is a clamp that holds the boot to the sump. It might be where you are leaking. This is not too complicated of a deal. You can either pull the dishwasher out to inspect it or drop the motor and pump assy with the boot attached. I have removed the pump and motor assy. by removing the drain hoses, disconnecting the wire harness. On the inside tub you would have to remove the filter screen and sump filter. The boot that clamps to the pump will be exposed. Push it in, remove the motor hanger, fold the boot over and pull out. As long as you have a couple inches of clearance from the motor bottom to the floor you can do it that way. To answer the first question, this is not a common complaint. Catriver..post back.
3/12/2007 8:02:12 PM • GE Profile... • Answered on Mar 12, 2007
I have a GE dishwasher model GLD4908T10BB and the light is on for rinse only but does not turn on and will not let me change the settings?
Try a power disconnect from the mains for 5 minutes and then plug it back in. It that doesn't fix it, the problem will be the main control board. Many parts are obsolete. https://www.google.com/search?q=GLD4908T10BB ..
3/14/2024 10:15:10 PM • GE Dishwashers • Answered on Mar 14, 2024
Ge dishwasher lower rack doesn't get clean
I have spent all my career in the catering and food industry with dishwashers of all shapes and sizes.The usual reason for this can be two fold.First make sure that the bottom spray arm spins freely. For various reasons they can stick and that means the spray only hits one place. If you spin it, it should spin at least 2 revolutions. Even if it does....Remove the bottom spray arm. The thing that makes it spin is the angled jets in either end. They will often block with debris, and the worst is lemon pips and cocktail sticks, even fluff. No one knows how fluff gets in there, but it does. At my last job at a VERY busy airport lounge putting literally hundreds of baskets through a day, the two filters had to be de-fluffed every day. The problem at home is that the fluff solidifies between uses. So look at those end two jets, poke with something and put water in from the jet end rinsing to the big hole in the centre. Put the plug in the sink so you can see what comes out. The turn the arm over and force a good jet of water into the big centre hole and it should show as a good jet at the ends. Then put the arm back and make sure it spins.Your machine has a strange item called a 4 port diverter valve. This part concerns me a bit as it appears that it may be supposed to move or at least has to be in the correct orientation. Some items like this have a rubber flap that really does divert the flow. Once gain, some type of debris can ruin its function. It looks easy enough to remove.504 - Diagram Number FOUR PORT DIVERTER AND PLUG ASSEMBLY WD19X26398https://www.geapplianceparts.com/store/parts/assembly/PDT715SYN3FSAnother trick is to whip the door open mid wash if it doesn't have a safety lock and see what the arm is doing and if it is spraying well.I hope this is more use than our friend Umar Waheed! We are getting a lot of the AI Chat GPT4 Points Jockeys! Usually after 40 to 100 answers, they ask "How do I cash out my points" :>D..
2/20/2024 7:24:14 PM • GE Dishwashers • Answered on Feb 20, 2024
GE dishwasher gives H2O code but it gets water!?!??!
kindly cehck the water inket valve Sometimes, the valve might not open fully during a cycle, causing water flow issues or it may be clogged
8/15/2023 8:36:20 AM • GE Dishwashers • Answered on Aug 15, 2023
GE Profile dishwasher gave a code of 888. What
Make sure the hot water is on
4/29/2023 4:09:04 PM • GE Dishwashers • Answered on Apr 29, 2023
Why is my GE dishwasher drain solenoid continuously burning up?
There could be a few reasons why your GE dishwasher drain solenoid keeps burning up:
  1. Overloading the dishwasher: Overloading the dishwasher can cause the motor to work harder, which in turn can cause the drain solenoid to burn out.
  2. Improper installation: If the drain solenoid is not installed correctly or there is a wiring issue, this can cause the solenoid to burn out.
  3. Clogs or blockages: If there are clogs or blockages in the dishwasher's drain line or garbage disposal, this can cause the motor to work harder and burn out the drain solenoid.
  4. Electrical issues: If there are electrical issues with the dishwasher, such as a short circuit, this can cause the solenoid to burn out.
To troubleshoot the issue, you may want to start by checking the dishwasher's drain line and garbage disposal for any clogs or blockages. You can also check the dishwasher's installation and wiring to ensure everything is properly connected. If the issue persists, you may need to consult a professional appliance repair technician to diagnose and fix the problem.
2/24/2023 6:39:12 AM • GE Dishwashers • Answered on Feb 24, 2023
GE Profile PDW8480JSS Built-in Dishwasher Logo
Popular Tags
22 questions posted
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
soap not coming
  • Dishwashers
