20 Most Recent Lexmark E260 Laser Printer Questions & Answers
Uninstall the printer and reinstall it.If you don't have the driver windows OS may recognize it depending on how old the printer is.Also the Mfg.'s website will have it
Lexmark E260... | Answered on Feb 02, 2018
Reset NVRAM
and enter
normal mode
1. Power on with top cover open and
both and buttons pressed.
2. Close cover once the light is
displayed.
Lexmark E260... | Answered on Feb 14, 2017
Please reset the pc count on your printer. Please click on the link below for the steps. http://bitly.com/r8ZhYJ
If you need further assistance, please contact Lexmark Technical Support Center.
Lexmark E260... | Answered on Sep 24, 2015
Go to any website that sells bulk ink and toner refills. They have chip resetters. You need to do this every time you refill . It cannot be bypassed.
The device statistics is found under 'Utilities' in 'Print stats'.
Lexmark E260... | Answered on Sep 02, 2014
If all lights are blinking, this is an indication that the printer is detecting a service error. Please press the continue button to the get secondary code indication. After pressing the continue button, please note which lights remain lighting up or blinking. For further information, please feel free to contact our Technical Support Hotline.
Lexmark E260... | Answered on Dec 17, 2012
The driver might have been corrupted. Please uninstall the driver and try the PCL5 driver on our website.
Lexmark E260... | Answered on Dec 06, 2012
Please try to use a Host-Based print driver, you may download this from support.lexmark.com and installed it on your computer.
For further assistance, please contact Lexmark Technical Support
Lexmark E260... | Answered on Jul 19, 2011
Press Continue twice to see the secondary code. The secondary code will indicate where to locate the problem.
For further assistance, please contact Lexmark Technical Support.
Lexmark E260... | Answered on Jul 15, 2011
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
If the printer is not printing, check the cables connecting the printer and the computer. Make sure it is properly connected. Check the settings on your computer if printer is set as a default printer and try printing a test page from the driver page. To do this open printer and faxes, right click on the printer >properties and click the button print test page.
If you are able to print a test page, check the settings of your application and make that the correct printer is selected.
If you have replaced the PC kit unit, please make sure to reset the pc count. Try the link below and follow the steps.
http://bitly.com/l1R8yE
Lexmark E260... | Answered on Jun 24, 2011
Buy some laser cleaner sheets and run them through the printer several times. If the cause is simply dirty rollers, that should take care of it. Otherwise, might need a technician to do a thorough cleaning.
Lexmark E260... | Answered on Apr 01, 2011
Please view the following video for Lexmark E260 Toner Refilling
Hope it helps! Good Luck!
CreativeTECH
Lexmark E260... | Answered on Mar 10, 2011
Access the manufacturer's web-site: http://support.lexmark.com
Enter 'E260' and do the search.
Select your Operating System.
Download the device-driver software.
Install the software.
Print a "test" page.
Lexmark E260... | Answered on Mar 06, 2011
You will need to install the drivers for the e260n. They can be found Here. Install drivers and you will be good to go.
Positive Feedback ALWAYS Appreciated :)
Lexmark E260 Laser Printer Logo
48 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
E Lexmark
  • E Lexmark
Most Popular Question
reset lexmark e260 chip
  • Office Equipment & Supplies
