20 Most Recent Veo Observer XT Network Camera Questions & Answers
I lost the driver for my 1.2mega pixel web cam
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download the Driver Magician from this link :
http://www.toggle.com/lv/group/view/kl34858/Driver_Magician.htm
Download the reg key from this link :
http://public.box.net/paul123
then doule click & select ok.
Run the program and select update drivers, it will list the list of pdated drivers.
Select the drivers and select download drivers.
If it does not download just select the driver you need and at the bottom you would see a link,
Just copy that link and download from your browser or download manager, I use orbit downloader.
or
You can also try this :
http://tinyurl.com/brslmb
Good Luck.
Live, Love, Luagh.
3/14/2018 4:18:39 PM • Veo Observer XT... • Answered on Mar 14, 2018
Drivers for veo network camera
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality.
2/11/2013 8:44:20 PM • Veo Observer XT... • Answered on Feb 11, 2013
I need veo observer REPLACEMENT power supply dc+5v
when replacing the power supply of your veo observer, be sure to check the required amperes and voltage are the same as in the damaged power supply that you want to replace.
3/22/2010 12:42:48 AM • Veo Observer XT... • Answered on Mar 22, 2010
Cannot establish network connection
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
3/7/2010 7:34:29 PM • Veo Observer XT... • Answered on Mar 07, 2010
Where can I get the drivers and software for my
the drivers are a free download available here.
http://wareseeker.com/Network-Internet/observer-6.2.zip/36279
7/9/2009 1:11:04 AM • Veo Observer XT... • Answered on Jul 09, 2009
Cameras have not IP address. how can I to get it?
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
1/14/2009 8:57:43 PM • Veo Observer XT... • Answered on Jan 14, 2009
Nexxtech webcam driver for windows m.e.
Hey could you send your driver to me please my email is [email protected]
11/18/2008 1:19:44 AM • Veo Observer XT... • Answered on Nov 18, 2008
No CD with my Veo Observer XT
The manual is available in .pdf format on internet. I bought one of these on ebay and have been using it successfully for years now.
11/12/2008 9:47:41 PM • Veo Observer XT... • Answered on Nov 12, 2008
Driver veo 650vs21x
Go to the manufacturer's website and download the necessary driver for your specific model. dd831a34-9bd5-4fcd-bf99-c101ea81719b-uirlbmmdnsc10qdkrvpu2msd-3-0.jpeg
3/23/2019 11:22:46 PM • Veo Observer... • Answered on Mar 23, 2019
Veo observer mac
http://veo-observer.software.filedudes.com/mac/
9/13/2014 12:14:16 AM • Veo Observer... • Answered on Sep 13, 2014
Can VEO 333VB32X connect to windows 10?
Yes it can connect at the top of window it show camera access for this device is on if it is off made it on .If camera access if off you cannot connect webcam and camera to your system and application
6/12/2021 12:44:39 PM • Veo Computers &... • Answered on Jun 12, 2021
0answers
2answers
A while ago(a long while
No and you can;t even get drivers for it unless you pay for them. Best to purchase a new camera.
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
A. Skype Setup:
B. Yahoo Setup:
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
Microphone
Speaker
Camera
Notes:
2/18/2014 2:55:07 PM • Veo Computers &... • Answered on Feb 18, 2014
Veo Observer XT Network Camera Logo
17 questions posted
Top Veo Computers & Internet Experts
ExpressFiX
ExpressFiX
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Observer Veo
  • Observer Veo
Most Popular Question
drivers veo network camera
  • Computers & Internet
