20 Most Recent
MSI Wind U120-020US Netbook Questions & Answers
Hello.
My built in Msi u120
the camera is a real camera in the screen bezel pointed to you
not to itself or the screen of any laptop
how can it see backwards.
a cell phone has front and rear camera
this PC is not a Cell phone.
answer 2
NO OS told at all we can not guess OS you run.
but the drivers are wrong and or MSI apps to make the camera work like new.
OS upgrade love to break cameras, did you?
the most confusing thing is
take pictures/ videos using the internet.
what does that mean? be clear on use or get wrong answers.
3/23/2022 2:18:24 PM •
MSI Wind...
Answered
on Mar 23, 2022
Reset password cmos msi wind
when i turn on my net book there is a password and i cant remember the password and i need it reset how would i reset it?
5/5/2018 7:12:46 PM •
MSI Wind...
Answered
on May 05, 2018
Battery falls out
Try to get something to hold it like duck taping the locking tabs over the battery
5/8/2012 4:20:17 PM •
MSI Wind...
Answered
on May 08, 2012
Won't boot
you might have to call and find out how to start the entire computor over from the begining, you will lose everything but it may work out and boot up. it sucks and im no expert but its an option.
4/22/2012 12:31:13 AM •
MSI Wind...
Answered
on Apr 22, 2012
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.2. Remove recharge plug3. Remove battery4. Leave it like this for about 5 minutes.5. Put everything back and power the laptop again Does it appear to charge the battery at all when plugged into AC? Can
you hear the charger humming when you put the brick up to your ear?
(while it's plugged into AC,You may have a bad motherboard
12/4/2011 8:41:20 PM •
MSI Wind...
Answered
on Dec 04, 2011
Computer not charging
the transformer which is small plastic box connected to the power cable could be damaged or the fuse has melted if the small box has broken you probably have to replace whole power cable the best and cheapest to buy a replacement from is amazon and amazon is very reliable and you can buy a cheap on there.hope this helps
4/3/2011 3:47:29 PM •
MSI Wind...
Answered
on Apr 03, 2011
Msi wind u120 ac connector quit working? problem @
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled
& the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the
area near the DC jack. Any defective/burned out components found should
be replaced, or you might need to replace the laptop's motherboard
altogether.
9/8/2010 6:04:55 PM •
MSI Wind...
Answered
on Sep 08, 2010
I want to do repair missing system file on my MSI
alternatively, use a windows cd as if you are installing a fresh copy. if it is xp you using, go until you accept the agreement by pressing f8. after that it will give you an option to press some keys to continue, press the R for recovery without formating, it will repair you windows and keep your data.
if it is vista, find a genuine copy, it will give you an option to upgrade you windows, and that too will not require you to loose your data, it will keep it.
alternatives can be found from my master: askleon.com.
thank you,
wonder
9/17/2009 10:01:29 AM •
MSI Wind...
Answered
on Sep 17, 2009
How to enter recovery mode
This is the easiest way that can be completed. Download Quick Boot tool from Google Play Store. Click Here to download, and Install this tool in your device. Now, Run this tools.
1/12/2015 2:45:09 AM •
MSI Wind...
Answered
on Jan 12, 2015
