20 Most Recent
Toshiba Portege M800 Notebook Questions & Answers
The dvd driver doesn't work.
Did you check your DVD player program setting?What about DVD region setting for? (If you use non-us DVD like PAL.)
Full system recovery
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook.2. When the machine Starts beeping; release the 0 key.3. When prompted by the warning screen; select Yes to continue with the systemrecovery.4. Select Recovery of Factory Default Software; click Next.5. Select Recover to out-of-box state. 6. Click Next again.7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
How to do a full system recovery for my toshiba protege m800
Restore Toshiba to Out of the Box ConditionIf your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook.2. When the machine Starts beeping; release the 0 key.3. When prompted by the warning screen; select Yes to continue with the systemrecovery.4. Select Recovery of Factory Default Software; click Next.5. Select Recover to out-of-box state. 6. Click Next again.7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
My laptop is not loading
I would contact www.toshiba.com amd speak to the technical department, they are very helpfull. It may be a RAM fault or a hard drive fault but as you have data on the drive, I don't want it to go pear shaped and for you to lose any data.
Hope that helps.
Unable to make calls thru Skype. I can hear the
Hi ,
Yes this is a common issue and can be resolved. First uninstall skype. Next install the sound drivers for thelaptopm. Reboot the laptop. Next download the latest skyp from
www.skype.com
Now it will start working. Please go to the sound in control pannel and make the settings as required.
Thank You for contacting Fixya and please accept the solution if it has helped you.
Mouse does not nove. Device manager shows no mouse
Go into the BIOS. When you first turn on the laptop there will be an option to go into the BIOS. Should be like F1, F2, something like that.
After you go into the BIOS go ahead and reset the BIOS to factory defaults, it will tell you what key to press to do that. After that let the laptop go back into windows. Check the device manager and see if the mouse shows up. If it doesn't then that means the ribbon cable for the mouse pad might be loose underneath it where it connects to the motherboard.
If you can get to that then take it out and the reseat it. If you go thru my steps and you notice that the mouse is recognized but not moving. Hold down the Fn key and then as your doing that press the key that has the mouse icon on it, that should get the mouse cursor to move.
