20 Most Recent
GE JBP30 Electric Kitchen Range Questions & Answers
I have changed the light
The little button on the bottom of the socket may be cooked ... Unplug the stove ... let me say again ... unplug the stove then inspect the socket ... pend the little tab in the button up a little ... it it is not there, replace the socket. Get a replacement socket at your local appliance parts store.
Thanks for your interest in FixYa.com
11/16/2010 1:45:04 AM •
GE JBP30...
Answered
on Nov 16, 2010
Range Oven clean cycle problem
An F2 error is the oven temp exceeded 590 Deg with the door unlocked.
I know you have been troubleshooting the door lock issue. There can be a problem with the micro-switch actuating arm of the door latch assembly.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-+JBP30BA4AD+-%3d%3dei245065&PartID=245065
If the actuation arm is bent you will get the symptom your describing. You can attempt to bend the actuating arm "upward" on the microswitch. The curved end of the arm should be even with the curved latch swing arm hole end when properly adjusted.
The switch can also be failing electrically with heat but highly unlikely. You may end up changing out the door latch assy. listed above to correct the problem. I still believe you can just adjust the micro-switch and save yourself some money.
Thanks for using FixYa.
Kelly
5/11/2010 10:01:48 PM •
GE JBP30...
Answered
on May 11, 2010
