20 Most Recent
LG VX9600 Cell Phone Questions & Answers
People unable to hear me
My phone had same problem like you are having, but I accidentally got my phone fall on an oil container and spoiled my mic. After changing microphone now working. I guess first option is to change mic. It wont even be soldered to board you can swap it and check. If problem still continues can check circuit.
Please watch this video. It will be useful for you in effectively use your browser. https://www.youtube.com/watch?v=9C3SRvhUMwY
My lg cx9600 screen is locked
Here is a list of options for your phone. Type for soft reset *#7780# . For hard reset *#7370# (you will lose everything) , or 1234 is common default password. you can also try: The code by default (unless changed by user) will be the last four digits of that phones phone number. If that does not work you will need to do a factory data reset. by
Reset lg versa
Tap “Menu” then tap “Settings & Tools” – “Phone Settings” – “Security”, for security purposes, enter in the last four digits of your wireless number (default), “Reset Default”, It’s done.
PS: Restore phone is a complete reset, you will lose everything saved. ex. contacts etc..
Also, default codes can vary. If the last 4 digits of your phone number does not work try: 1234 or 12345 or 0000 or 0000
I think somone might have
if the same was done by lower grade software then bluetooth must be used so close always your bluetooth,,, if the same done by higher or paid service then you must reinstall new and fresh firmware into your mobile to clean the spy software from your phone. (any how it is very difficult to install them into your phone if the same is used by you only)
LG Versa Problems
my Lg Versa 9600 wont let me post on othe peoples post on FaceBook since this morning , what can I do to change this
My Verizon LG Versa will
On some phones, there is a limit to the number of times you can enter the same number, even if you delete it. The number is still there, just marked deleted. Usually limited to 10 or less. It will not be actually removed until all memory and sometimes the phone is factory reset. You may be able to fool it by adding +1 before the area code when you enter the number. It may not recognize it as the same number and the +1 is ignored if it is not long distance. Try als changing the name somewhat.
