20 Most Recent
Sharp LC-32SB23U 32 in. LCD TV Questions & Answers
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Problem With the Sharp TV LC-32SB23U 32in LCD TV Serial No# 810825838
http://electro-medical.blogspot.com/
brand name" to your device, in the "
My 70 inch Sharp TV flashes but it wont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Volume goes off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Flashing power and OPC lights on tv and does not come on. What is OPC and how can this be fixed?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Color
Contact cable provider.
Picture goes blck, power button flashing green
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "
MOSAIC" view.
Not on
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
For more information, check the link http://electronicshelponline.blogspot.com/
Sharp 32 32sb3u
The resolution that the Xbox is pushing out is most likely too much for the TV, and it switches off because it can't physically display the signal. Try hooking the xbox to another TV (if you have one) and setting the resolution to something in the neighborhood of 420p so that you can see the screen. After you do this, take it back to your TV and switch it slowly up in resolution until it blinks out. When it blinks out, you know that the resolution is too much.Change it back to the next lowest resolution and play away.
