20 Most Recent
Sylvania LC370SS9 LCD TV Questions & Answers
Sylvania lc370ss9. tv just quit.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
4/25/2017 11:40:02 AM •
Sylvania...
Answered
on Apr 25, 2017
Update tv firmware
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Firmware update procedure to many popular brand TVs are given.
7/24/2014 2:25:30 AM •
Sylvania...
Answered
on Jul 24, 2014
Trouble shooting
The screen controller board has failed. It's the one that has one or two flat ribbon cables connected to it
1/6/2014 7:55:41 AM •
Sylvania...
Answered
on Jan 06, 2014
How do I fix it?
I'm having the same problem with my RCA. I was told it is probably a loose ground wire. GOOD LUCK
7/2/2012 5:28:55 AM •
Sylvania...
Answered
on Jul 02, 2012
I need a new screen
buy a new set as part needed alone will cost more than the new set will.
6/8/2012 2:52:17 PM •
Sylvania...
Answered
on Jun 08, 2012
How do you Wall mount
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
6/17/2011 10:15:17 PM •
Sylvania...
Answered
on Jun 17, 2011
Our tv is only a year old. It turns off and on by
Some people have been able to temporarily get the set to work. Unplug the set for an hour or so to cool off. Plug the set in and start it. Sometimes it will work for a short time.
THIS IS NOT A FIX. This will show that heat can cause the part to fail.
If this set is under warranty you should return it to get it fix/replace. If not then;
This sounds like the power supply board is failing. The electrolytic capacitors on the board may need to be replaced.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(soldering ) or have a friend with knowledge/skill you can fix it.
>Unplug the set and any cables.
>Remove the back cover.
>look at the capacitors on the power supply board. If the top of any of them are bulging up then that is a problem.
>You will have to replace ALL the electrolytic capacitors except for perhaps the large one.
>Disconnect and remove the power supply board. Handle by the edges to prevent contaminates and static electricity.> Use ones with the same farad rating
> Use ones with the same or higher voltage rating> Use ones with high temperature rating> Install one at a time to prevent mix-up and keep the polarity correct.
> Leave a space between the PC board and the bottom of the capacitors for expansion. They heat up.> Replace power supply board and reconnect cables..> Replace back cover.
THIS IS AN INDUSTRY WIDE PROBLEM AFFECTING MANY COMPANIES AND PRODUCTS.
One source for some good capacitors is NTE. Try nteinc.com for a local outlet.You can also search for other sources. Some companies even sell all the capacitors in a kit.
Total price of parts should be < $20.00
Yes you can replace the power board but if the capacitors have not been replaced they will eventually fail also.
If the power supply board is not the problem, you can consider replacing the inverter board.
2/18/2011 5:06:30 PM •
Sylvania...
Answered
on Feb 18, 2011
