20 Most Recent Samsung PN58B550 58 in. Plasma HDTV Questions & Answers
How to change resolution in samsung 58" plasma tv?
Go in to you setting aspect ratio then change it there
8/26/2016 11:52:15 PM • Samsung PN58B550... • Answered on Aug 26, 2016
TV shuts off with volume control
Improper signal frequency goes to the TV from the remote control. Check your remote control for fault. Gopakumar Gopalan Google
9/21/2015 1:42:38 PM • Samsung PN58B550... • Answered on Sep 21, 2015
Where can I get IC Chip Panasonic AN16479A
I would look at Ali Express. It takes a while to receive stuff from China but they have a lot of parts.
11/19/2014 5:48:24 PM • Samsung PN58B550... • Answered on Nov 19, 2014
2answers
Small Crack on the screen and the 58 inch plasma
The screen needs to be replaced if it is cracked, usually it is not economical to repair, but it is worth getting a quote.
11/14/2014 6:40:51 PM • Samsung PN58B550... • Answered on Nov 14, 2014
Sound but not image
Speakers turned off or disconnected?Does a DVD have audio when connected to a rear input?If a box of some type is in use has it been rebooted?
12/12/2012 3:24:23 PM • Samsung PN58B550... • Answered on Dec 12, 2012
I need to replace the
vancebaldwin.com but it's not worth it.
5/22/2011 10:19:07 PM • Samsung PN58B550... • Answered on May 22, 2011
We just moved, our t.v. was packed and moved
Try adding those ferrite core magnets to your power cord, you should have got one with the tv. If this doesn't help, might need to have a technician look at it.
3/8/2011 5:45:11 PM • Samsung PN58B550... • Answered on Mar 08, 2011
New samsung series 5 just out of the box and the
if it's new and out of the box, the 12 month guarantee will cover all work or even a replacement.
4/11/2010 4:15:41 PM • Samsung PN58B550... • Answered on Apr 11, 2010
What size screws does a SAMSUNG TV PN 51E530 require for a stand mount
I just looked up the manual online and it clearly shows that the screw size is M4 x L12 metric screws
6/2/2022 7:28:11 PM • Samsung PN... • Answered on Jun 02, 2022
I have a Samsung PN50B530S3F plasma TV 2009. It has a black horizontal lines problem.
check the display strip. un plug it and fix it
5/14/2019 12:54:56 PM • Samsung PN... • Answered on May 14, 2019
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
1/5/2017 7:30:41 PM • Samsung PN... • Answered on Jan 05, 2017
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
6/30/2016 2:20:35 AM • Samsung PN... • Answered on Jun 30, 2016
Samsung PN58B550 58 in. Plasma HDTV Logo
22 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
PN Samsung
  • PN Samsung
Most Popular Question
get ic chip panasonic an16479a
  • Televison & Video
