20 Most Recent
Samsung LN46B530 LCD TV Questions & Answers
I have a Samsung LN46B530
These lines came on to the tv LCD screen panel by itself?Yes,than the board that call the T-CON board it is dying to causes this problems,if these black lines problems causes by u or an object by hitting it to the tv LCD screen panel itself,it can't be repair,the tv LCD screen panel itself it is dead and leaking radiations.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
My Samsung is stuck in powering on and off
Take the tv aparts,check the tv whole power supply board,that the board where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors parts.These capacitors parts are alway bulges up or puffing up on to it tops.U have all the tools also know basic electronic also soldering work too.Replaced all those dying capacitors parts are bulging up or puffing up onto it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Purchased universal wall mount kit for Samsung LN46B530
I have found that Home Depot and Lowe's (the bigger hardware stores) do not carry something like this. I alway got to my Local ACE Hardware where they have a whole isle with nothing but screws, nuts, bolts and fasteners. I always find what I am looking for there. So if you have a little hardware store in your area then I suggest trying them. It is alittle more expensive than the bigger guys but always worth it cause you can buy one, Two or 100.
How do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
The TV is only two months old.. There are green spots everywhere
The LCD screen is going bad. The green spots are where the LCD junction is not being activated by the voltage. This usually happens when the screen is begining to malfunction. Also I would check the connectors between the screen and the screen driver board.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-tecgnologies-llc.com
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
