20 Most Recent
Samsung PN50B450 50 in. Plasma TV Questions & Answers
Will not turn on red led blinks and clicking sound
I don't have a solution but my Samsung 50" 720P Plasma is doing the same thing. It's already been in the shop for a new panel and now just after the warrenty runs out this happens. I'm NOT recomending this TV to anyone. NO MORE SAMSUNG for me...
Tv sparks bad when i apply the cable cord to it
EXTREME DANGER!!!!!
PLEASE LISTEN CLOSELY:
all appliances made in the last forty years have a polarized power cord.
One pin on power plug is small and other larger--the larger goes to the neutral side of the electrical outlet.
If you get sparks when you hook up the coax to the cable fitting--only one of two possible reasons.
Either the polarized cord has been defeated (plug modified) or the outlet you are plugged into is not wired right.
Understand--it does not have to be at the set you are using---if somewhere else in you home a cord is defeated or an outlet is bad--it will feed the problem via the coax to every other set in the home connected to the same line.
What you are seeing if you get sparks is the coax fitting has 120 volts AC getting to it either by the coax or from the power outlet--
The easy way to find this is disconnect all coax connectors in the home and with a voltmeter hooked to a earth ground (like a ground rod or pipe made of metal) measure for AC voltage to the coax.
THIS IS A VERY DANGEROUS SITUATION-BE VERY CAREFUL--
If even one set or outlet is bad it will feed this via the coax to all sets in the home---I have seen this before-yes it can destroy a TV! but it can also hurt or kill someone--this is the reason all power cords are now polarized.
IF YOU HAVE ANY QUESTIONS ASK ME--IF IN DOUBT HAVE AN ELECTRICAL EXPERT CHECK THE WIRING AND MEASURE FOR AC VOLTAGE TO THE CABLE--ac voltage can kill--it is the same as connecting a wall outlet to the exposed areas of the set.
THIS IS SERIOUS STUFF--DO NOT TREAT IT LIGHTLY!
SD TECH
