20 Most Recent
AOC L22W898 22 in. LCD TV Questions & Answers
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
No picture, but have sound
Does it do this in both TV and monitor mode or just monitor mode? If in both modes, the high voltage power supply that provides power to illuminate the screen is probably bad.Have a repair shop check the high voltage power supply.
Aoc tc does not have cable or tv in input sorce how do you get it back
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
REMOTE doesn't work on AOC L22W898
Change your batteries. Clean the battery contacts. Use a digital camera pointed at the LED on the remote to see if it is working. It might actually be the TV, but it is usually the remote.
Locked menu press screen
If you wish to get some details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic / Timeslide / Flipcard, can be
selected by the
drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the
brand name / model number / IC used, in the
search box at the top right of the display window. Unlock procedures to many brand TVs are given in detail.
