20 Most Recent
Vodafone Motorola E770V mobile phone Questions & Answers
Wht is the puk code for vodafone 527
My dear:Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly SolvedBut:Don't try to enter a PUK code without knowing the right one.You need to call your service provider to get this code. It can be as many as 8 digits, and it is random. If you enter too many wrong codes, you can permanently damage the device. So Please You Go to Service officeand Get the Duplicate Sim From Office OpraterSame Your No Problem will Solved
2/5/2013 11:17:53 AM •
Vodafone...
Answered
on Feb 05, 2013
Unlock code motorola
try to go to fonezone.this site helps unlock any kind of phone
hope this will help your problems
3/6/2011 11:52:57 PM •
Vodafone...
Answered
on Mar 06, 2011
My motorola phone does not
Where did you get the handset from. If this is from Vodafone then you will need to spek to them.If the handset is not you might need a handset unlocking code.
2/8/2011 7:36:35 PM •
Vodafone...
Answered
on Feb 08, 2011
I had received mms from
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
1/25/2011 4:40:38 AM •
Vodafone...
Answered
on Jan 25, 2011
I have a vodafone phone and i had a security pin
Hi,the best and only way to get the unlock code for your sagem phone,is to contact your service provider(vodafone) and request for the unlock code,which will be given to you for free.
However,they might be asking some funny questions,just tell them you are travelling to a country where vodafone does not exist like Ghana.
Thanks and take care
8/25/2010 8:31:03 PM •
Vodafone...
Answered
on Aug 25, 2010
How to fix network on vodafone 785?
In order to do that:
1. Go to Settings
2. Choose the option More Networks in the Connection settings.
3. Then tap on Mobile Networks
4. Find the Network mode.
5. Change the Network from 3G to 2G.
A much cheaper solution is to by a 3G/GMS antenna. It is usually quite small and you can put it anywhere in the room. Remember that the higher the antenna is located, the better the signal is. If you need an antenna for a bigger building we would recommend hiring a company which specializes in that field.
How to unlock vodafone ce 1588
You would have to contact an unlocking company or the carrier directly for the unlocking code. Also, browse over to Swappa and check if the phone is blacklisted or blocked on just the carrier's network. Some get blocked on ALL major networks and can only be used outside of the US.
