20 Most Recent
GE JGBS20 Gas Kitchen Range Questions & Answers
I have a GE Range that has started acting up. it
Yes, most likely the broil relay got welded shut. The company will want to sell you a whole new control board for about $200.00 -- but if you have any soldering skills, you can purchase a new replay for around $6.50.
Gas oven not lighting
Hi the problem here is the igniter. Take the floor of the oven out and then the flame spreader. The igniter will be located at the back of the burner. Set the oven for 350, if the igniter does not light then test it with an ohms meter it should read continuity. If it reads open you should replace it. If the igniter does glow it still could be bad, the igniter should glow bright yellow to the point you can't look at it. If the igniter glows orange/yellow it is bad you will need to replace it. If you have any other questions please feel free to comment. Mike
How to install a replacement oven ignitor on a
your model is not complete so i am sending you a breakdown of a JGBS20 gas range. there should be more to the model and you can usually find it on the frame of the stove after opening the oven drawer. anyway, the igniter is #218 in the picture. maybe it will help you somewhat to figure out what needs to come off to change it. hope this helps.
The display doesn't work on my ge model JBP21GS1WH, however the burners work fine, is there a reset or something?
No reset found in the manual. You can try this and hope it works..
Turn off the circut Breaker to the stove for 5 minutes to see if it resets. Checking around the net I've only found
"Item Discontinued"
- The part is no longer sold by the manufacturer.
- The manufacturer does not stock any substitute parts to replace this one and therefore, unfortunately, we cannot obtain or recommend a substitution for this part.
- We cannot obtain the part through any other means.
Darn..
