20 Most Recent Sanyo VPC-S1080 Digital Camera Questions & Answers
5answers
I have a VPC S 1085 modle with memory card. I have
First of all, you should stop saving any new files to you canon camera (or SD card) or taking new pictures with you camera.Then find some photo recovery software from this site Best Computer Software, which is of high quality and easy-to-use.Digital Photo Recovery for CameraHere are the steps:Step 1: Download and install the Digital Photo Recovery Software Asoftech Photo Recovery.Step 2: Connect your camera (or SD card, memory card etc) to you PC.Step 3: Scan the source drive where your lost pictures located.Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
11/4/2013 6:53:34 AM • Sanyo VPC-S1080... • Answered on Nov 04, 2013
2answers
When I turn on my camera it says "card locked" what do I do ?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
12/14/2012 2:05:36 PM • Sanyo VPC-S1080... • Answered on Dec 14, 2012
What is frame number reset
If you decide to reset the numbers, your camera will start numbering the new pictures from 000 all over again. This can cause problems when you try to download because your computer will think you've already downloaded pics with those numbers. Don't reset....your camera will continue to number the pics consecutively even after you download and empty the card.
8/17/2011 11:21:37 PM • Sanyo VPC-S1080... • Answered on Aug 17, 2011
How do I download pictures?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
1/22/2011 5:29:38 AM • Sanyo VPC-S1080... • Answered on Jan 22, 2011
How do i get pictures from my computer to my
Most likely the software that you used to transfer the pictures off of the camera also deleted the pictures off the camera when it was done transferring them.
12/30/2010 7:48:51 PM • Sanyo VPC-S1080... • Answered on Dec 30, 2010
Every time i turn on
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/18/2010 9:38:48 AM • Sanyo VPC-S1080... • Answered on Sep 18, 2010
I erased all my pictures
Hello
Download THIS.
Download this free tool and run it on you card and it should be able to recover all pictures provided that you have not used the card since formatting. I recommend using a card reader for this.
After downloading and running (no installation required) , simply select deep scan and your memory card and it will start scanning, To recover a found file , right click it and select save.
Please note that the file names will probably not be available and also that some of the properties of the photo like date taken could be lost.
Please let me know when you have recovered your pictures safely or contact me if you need further assistance.
Regards
Andrea
9/7/2010 1:36:52 AM • Sanyo VPC-S1080... • Answered on Sep 07, 2010
The lens wont open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/5/2010 10:01:39 PM • Sanyo VPC-S1080... • Answered on Jul 05, 2010
Every time i try to upload pictures to my
Use a card reader instead of your camera. Works every time.
7/2/2010 12:22:22 PM • Sanyo VPC-S1080... • Answered on Jul 02, 2010
How do i transfer my picture from my camera to my
Once you install any software your camera came with, a little balloon should appear at the bottom-right corner of your screen saying your software was installed successfully and is ready to use. Your camera should come with the appropriate USB cable too (the cable with a rectangular-shaped end, about 3 feet.) Once this is all completed, follow these steps:
1) Go to the Start menu ---> My Computer, you should then see your camera. Double-click that icon on the screen.
2) There are usually two folders, go into the one that (should say) DCIM. This is the folder your camera saves images onto. Your photos should be inside.
3) Cut or copy them anywhere in your computer where you will find them easily.
6/29/2010 10:58:33 PM • Sanyo VPC-S1080... • Answered on Jun 29, 2010
Will not turn on
5/5/2010 1:32:30 AM • Sanyo VPC-S1080... • Answered on May 05, 2010
Everytime i try to zoom my camera shuts off
Two possibilities here. The lens housing is damage, and when you try to zoom it is unable to do so. You would be more inclined to get a message about this as opposed to the camera powering down.
Second option is a low power situation. If you are using non rechargeable batteries, you might find they are not up to the task. I have found this with few cameras. If you are using rechargeable batteries, they may be end of life, and no longer packing the same punch that the once were.
Although rechargeable batteries have 1.2 volts instead of 1.5, they can have more power with higher capacity. I tend to use 18mAh or higher batteries in my camera, especially for zooming, but make sure to use the guidelines for charging and recharging these so they will last a long time.
4/23/2010 2:54:21 PM • Sanyo VPC-S1080... • Answered on Apr 23, 2010
I turn my camera on
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
3/16/2010 8:10:28 PM • Sanyo VPC-S1080... • Answered on Mar 16, 2010
I didn't receive a user's manual with my VPC-S1085
c928052.jpg This is SANYO VPC-S1080 User Manual.
If you find this helpful please vote with high rank.
2/25/2010 3:40:14 PM • Sanyo VPC-S1080... • Answered on Feb 25, 2010
Camera turns on and off automatically
Two ways to reset a camera: 1. go into the menu and find "reset"...follow the on-screen instructions. 2. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
1/31/2010 9:09:04 PM • Sanyo VPC-S1080... • Answered on Jan 31, 2010
My camera a VPC-S1085 came with a usb cord and a
Do what the pros do...use a card reader.
1/18/2010 10:47:12 PM • Sanyo VPC-S1080... • Answered on Jan 18, 2010
Sanyo VPC-S1080 Digital Camera Logo
Popular Tags
32 questions posted
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
vpc s 1085 modle memory card
  • Cameras
