20 Most Recent
Sanyo Xacti VPC-T1075 10MP Digital Camera with 3x Optical Zoom 2.7" LCD- Purple Questions & Answers
What is the best program to down load sanyo xacti
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging programs.
One of the better free programs is Picasa ( http://picasa.google.com ). If you want to go professional-grade, you can try Adobe Lightroom ( http://www.adobe.com ).
Card is locked. how do i unlock card so i can take
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
My USB cable is playing up!
Usually this thing occurs because of "Not safly removing the Hardware" (Cable, in your Case) or if the cable is just plugged-in and out frequently.
So try to Plug it properly, it shouldn't be loose.
And once this Unrecognition occurs, usually restarting your PC can solve the Problem.
Also check that your connecter and port isn't loose, that makes the cable to Connect/Disconnect.
Regards,
Waqar.
Why won't Sanyo Xacti camera does not power on after being charged?
not car moved this to camera
no model told at all
the batteries are no good or connections rusty on most
many of these are 13 years old and sold as new by liars endless on the web .
models
vcp-nnn (lots )
DMX-nnn (lots)
the endless list is here.
what it uses inside who knows lacking model
the battery is bad, or allowed to leak and damaged connectors.
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.The manual is still online.Success
How to get my picture right side up
I'm thinking you mean it is upside down on the camera screen. ??? Old man told me one time. When you get tired of trying to make that thing work right - read the instruction.
Sanyo VPC-T1496 Battery issues
Talk to Kastar and tell them there battery messed up your camera. I am assuming the camera was working OK when you got it.
