20 Most Recent Pentax X70 Digital Camera Questions & Answers
0answers
Memory error
Be the first to answer 12/6/2017 10:03:03 AM • Pentax X70... • Posted on Dec 06, 2017Be the first to answer
Can't see anything through the eypiece
To switch between the LCD screen and the viewfinder use the button EVF/LCD. to switch back, use the same button.
11/5/2013 1:48:21 PM • Pentax X70... • Answered on Nov 05, 2013
Can't see through the eyepiece at all. It's black
Some of these cameras have a button that you have to press before you can see out the view finder.
11/4/2013 7:34:43 AM • Pentax X70... • Answered on Nov 04, 2013
Memory Error
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
10/3/2012 8:03:01 AM • Pentax X70... • Answered on Oct 03, 2012
I have a different computer and i lost my software for my Pentax x70
You can use Picasa from Google its freepicasa.google.com/
7/7/2012 11:49:22 PM • Pentax X70... • Answered on Jul 07, 2012
2answers
Joecamera showing locked card will not format
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
6/21/2011 7:58:36 PM • Pentax X70... • Answered on Jun 21, 2011
How do I disconnect The protection from deletion
While reviewing the protected picture, press cursor-down to bring up the Playback Mode Palette. Use cursor-left/right to select Protect (the key icon) and press the OK button. Press cursor-up to select "Single Image/Sound" and press OK. Use cursor-up/down to select "Unprotect". Press OK.
Full details are in the "Protecting images and Sound Files from Deletion (Protect)" section of the manual (page 170 in my copy). If you need a manual, you can download one at
http://www.pentaximaging.com/images/temp/63389987065168840454432X70%20Manual_English.pdf
6/20/2011 5:10:27 PM • Pentax X70... • Answered on Jun 20, 2011
Instruction manual in Spanish,how do i get one in
9/20/2010 8:09:35 PM • Pentax X70... • Answered on Sep 20, 2010
Pentax Optio A10 camera turns on, the lens extends, the whistle sounds, and the screen displays battery level, & indicators. The problem is the screen itself is dark as if there is a lens cover on.
Normal people can't fix electronic cameras, you need to be an electronics engineer and an optical engineer. Take to a Camera Service Centre for evaluation and repair.
1/28/2024 6:21:51 AM • Pentax Cameras • Answered on Jan 28, 2024
Why isn't my K100D Flash not working?
Hi, please ensure that you've not used the camera for more than the advised amount of time by the manufacturer. Also, you can attempt to use the same brand/type of batteries as was including with your camera when you got it. Some manufacturers put internal fimware/software restrictions on their devices. For printers, this would be done for cartridges and in the case of your camera, it would be for batteries. Lastly, I would check that your sd card isn't full before calling Pentax to refer you to a repair shop. Thank you.
12/27/2022 1:20:26 AM • Pentax Cameras • Answered on Dec 27, 2022
Pentax Espio 60S "E2" error
Hi for anyone reading this! My 60s was just flashing with this but I fixed it. Took the batteries out, swapped them and that didn't work. Tried to put the old ones back in a few minutes later and then it was fine! Just fiddle around with it. Hope this helps.
12/12/2022 5:16:29 PM • Pentax Cameras • Answered on Dec 12, 2022
2answers
Hi...I won a Pentax digital camera K1100 but it came without instructions or a memory card. So I would really like to know how to use it and what memory card needs to go into it. I would really appreciate your help!
Download here. Section for discontinued models
http://www.ricoh-imaging.co.jp/english/support/download_manual.html
12/26/2019 3:28:50 AM • Pentax Cameras • Answered on Dec 26, 2019
My Pentax e30 will not record video files
http://www.ricoh-imaging.co.jp/english/support/man-pdf/optio-e30.pdf Instruction manual Does the SD card have enough room / is it fast enough for video? (the E30 records Standard def video so it should be OK) Do you get any error messages at all? Does it allow you to record video and then fail, or can you not activate recording in the first place?
11/5/2019 12:42:18 AM • Pentax Cameras • Answered on Nov 05, 2019
I have an old Pentax sv camera where can I get a users manual
Hi, Penny, I'm sure you will get a great deal of pleasure out of your new acquisition. To get a manual, try using Google 'Pentax SV camera manual'. You can get a great deal of help, advice and assistance from PentaxForums.com as well.
10/4/2019 10:00:47 PM • Pentax Cameras • Answered on Oct 04, 2019
My pentax smart head does not come on automatically...I have to press the red knob for it to come on
To what camera does this statement (it is not a query) apply ?
9/28/2019 4:53:17 PM • Pentax Cameras • Answered on Sep 28, 2019
I need a driver update for my pentax optio rx18. can download one from your website
Hello, Susan -Fixya.com does not have updated drivers for any computerized equipment. If you have not already done so, I suggest you contact Pentax directly regarding an updated driver for your Optio RX18.Pentax is owned by Richoh.You may be able to find assistance from another Optio RX18 owner through the PentaxForums.com :https://www.pentaxforums.com/forums/7-pentax-compact-cameras/194995-pentax-optio-rx18-rz18.htmlYou will need to register (free) to post a question on a forums.Best wishes.
9/4/2019 10:26:14 PM • Pentax Cameras • Answered on Sep 04, 2019
Pentax X70 Digital Camera Logo
15 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Pentax Cameras
  • Pentax Cameras
Most Popular Question
see anything eypiece
  • Cameras
