20 Most Recent Nikon COOLPIX S230 Digital Camera Questions & Answers
Where can i get cables for charging for the coolpix S230
Probably either local camera dealer or Ebay.
7/1/2016 9:56:20 PM • Nikon COOLPIX... • Answered on Jul 01, 2016
The time and date are set on my Coolpix S230. The Date Imprint is on and it puts the date on pictures. However, when I download the pictures to my computer, the Date Taken info is missing.
What software are you using? If you are using the ViewNX 2 from Nikon (updated with the patches), it should have the correct date taken information in the EXIF data. However, if you are using the older ViewNX software, then the software can corrupt the EXIF information or merely fails to download it with the picture. I'd suggest you first check if your software is up to date. Try here: https://support.nikonusa.com/app/answers/detail/a_id/61/session/L3RpbWUvMTQ2NTUzMDUwMy9zaWQvTHNYeVZGU20%3D for the current versions of various Nikon software. Please add a comment with the software version that you are using for extra support. I hope this helps. Cindy Wells
6/12/2016 12:40:10 AM • Nikon COOLPIX... • Answered on Jun 12, 2016
CONTINUOSLY ZOOMS IN AN OUT
Hi, if its under warranty you have to get it checked .
1/15/2016 10:59:11 PM • Nikon COOLPIX... • Answered on Jan 15, 2016
Error raise flash on nikon coolpix p500
hello sir I have Nikon p500 but if I will open flash message on display raise flash so what will I do how I will slove the problem my cam
10/6/2014 11:29:05 PM • Nikon COOLPIX... • Answered on Oct 06, 2014
Nikon coolpix S8200 won't connect to mac and download pictures
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
9/23/2014 4:14:34 PM • Nikon COOLPIX... • Answered on Sep 23, 2014
How ca I change language on my Nikon s230 camera
Press the menu button. Scroll to the setup menu (monkey wrench symbol). Press the right arrow and scroll down to language. Right arrow again and scroll to the language you want and then press enter (center button).
8/14/2014 4:40:08 AM • Nikon COOLPIX... • Answered on Aug 14, 2014
Can a cracked lense be replaced?
Hi The whole assembly has to be replaced. I would consult with the technician and yes it is replaceable only by the proffessional. terry
7/31/2014 5:00:49 PM • Nikon COOLPIX... • Answered on Jul 31, 2014
Go on Nikon's website and find the nearest Nikon Service Center. They can give you a price. However, my educated guess is that will probably cost considerably more then the camera is worth.
7/18/2014 12:56:54 AM • Nikon COOLPIX... • Answered on Jul 18, 2014
Nikon s5200 will not turn on
Hi please do double checks your battery. Make sure to try it out with the brand new one. The best way is to take it to the repair shop and ask the technician to check the battery condition. Most don't charges money and at the same time they tell you the estimate cost to repair it. sually buy new one is cheaper than repair depends on the camera some may already experience a major problem within electronic board or mechanical which not worst it to repair. Hope this help! terry
7/4/2014 7:29:23 PM • Nikon COOLPIX... • Answered on Jul 04, 2014
Serial number
Look on the nameplate label on the camera's bottom on the opposite end from the screw threads for mounting the camera to a tripod.
6/8/2014 6:14:59 PM • Nikon COOLPIX... • Answered on Jun 08, 2014
How can i know my serial no of nikon s230 camera
On the bottom of your camera, on the side opposite the screw threads for a tripod, you will see a long gray label or plate. Although it may be small and hard to read, it is on that label or plate
6/8/2014 6:13:22 PM • Nikon COOLPIX... • Answered on Jun 08, 2014
I have pictures on the camera and not a sd card
nikon camera drivers for laptop? (get pictures off) upgrade firmware for camera? (maybe read SD cards)
5/25/2014 6:51:07 AM • Nikon COOLPIX... • Answered on May 25, 2014
Coolpix S230 flash does not work even with updated firmware, red flash warning light blinks but no flash
remove the update..... look for the previous firmware and re-install.
5/25/2014 3:45:27 AM • Nikon COOLPIX... • Answered on May 25, 2014
tip
Nikon CoolPix S230
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S230-Digital-Cameras-review-manual/id/23241bh242/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
0answers
When i try to view my pictures I get a msg that
you memory card needs a data recovery. The files should all be there if you don't overwrite them and can be retrieved. Try your local camera store.
2/13/2014 10:31:44 AM • Nikon COOLPIX... • Answered on Feb 13, 2014
My camera won't take pictures with the flash on and when i try the red light just blinks. only takes pictures with no flash.
When your flash light (I mean the part that gives the flash) or the capacitor that stores the power for the flash are defect. you won't see a flash. When a red light comes on, when actually the flash should fire, the most likely the capacitor is defect. The electronics sensed it could not reach the voltage needed to fire the flash. It also could mean your battery can't deliver enough to charge the capacitor, but is that was the case the battery indicator should tell you.
1/20/2014 2:08:27 PM • Nikon COOLPIX... • Answered on Jan 20, 2014
Nikon COOLPIX S230 Digital Camera Logo
273 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
cracked lense replaced
  • Cameras
