20 Most Recent
Yamaha 2006 VK Professional Questions & Answers
2007 vk professional running hot,engine light on,codes 21,84 on
I have the book but I cant find the codes.
So find out if your rad fan is coming on. If it does then pull out your thermostat and place it in a pot of water and see at what temp it opens at. The open temp should be stamped on the thermostat.
If it is stuck closed or opening to slow, replace stat.
How to adjust gear chain on Yamaha VK pro
Locate chain tension bolt.
Loosen locknut.
With 2 fingers tighten the lock bolt until it is tight.(not crazy tight)
Then back off the lock bolt 1/4 of a turn.
Hold bolt and tighten lock nut.
You are done now.
Ignition wont work on a vk professional
Check your fuses. use a ohm meter.
use a test light to see if you have power to your ignition switch.
if not check your relays.
if you have power to your switch turn it to the on position, see if you have power there. If you have power there, then turn it to the start position,see if there is power there. if not replace switch.
Hope this helps.
10/11/2014 11:30:04 PM •
Yamaha VK...
Answered
on Oct 11, 2014
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
