20 Most Recent
Arctic Cat 2006 F6 Firecat EFI Sno Pro Questions & Answers
Boggs at 18-24 mph
Check the inner bushing on the secondary clutch,it may have popped out.
600 triple engine bogs
There's a number of things it can be first check throttle switch bypass all switches at the base it it still bog stator
2008 90 atv
If you dont have a fuel problem,change the external coil.
Arctic cat problems
Sounds like you have one of a few issues:
Clogged Main Jets
Cut Off on the Throttle restricting your running
Compression Test the Engine and see that the PTO Cylinder is at least a 110-120 Compression and the split between is not more than 10 psi
