20 Most Recent Yamaha 2012 WaveRunner FX Cruiser SHO Questions & Answers
Must be some obstruction in there. Probably just before the water pump of just after.
Yamaha Boating | Answered on Oct 17, 2019
Two things depreciate faster than a car and they are boats and rvs. A vintage yamaha is a nice term for older yamaha. I will be worth what someone wants to pay for it. That said, if parts are still available and it runs well, no work needed, you may get $1000 to $2000 for it. But that depends on the area you are in and what other used ones are going for. All you can do is offer to sell it for some amount of money and see if anyone calls. Lower the price if no takers.
Yamaha Boating | Answered on Oct 12, 2019
Yamaha would be a possible source.
Yamaha Boating | Answered on Oct 01, 2019
Most likely, (1) it's an old worn out battery, low charge, poor or corroded cable connections. Inspect and clean them. You may want to jumper battery with your car battery. If problem persists, (2) check starter solenoid connections and output connections. (3) As a last culprit, it could be a bad starter. And make sure your engine is not frozen. (Take spark plugs out and turn the flywheel by hand).
Yamaha Boating | Answered on Sep 29, 2019
I believe the P65 is a small engine with 3.5 hp.
Yamaha Boating | Answered on Sep 19, 2019
I got this free Pdf manual from reliable-store. com for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
Yamaha Boating | Answered on Aug 21, 2019
Yamaha Boating | Answered on Aug 20, 2019
Not a problem if 1 drops below 60 issues will start. Put 5 oz of marvel mystery oil in the cylinder to help free up the rings. Pour in turn over engine do not start. Let sit over night.
It should have a rubber hub pressed into the prop. It can go bad and is in place of a shear pin. The rubber hub should allow the prop to turn at idle speed but will slip at higher speeds. You can get a new hub pressed into the old prop.
Yamaha Boating | Answered on Jul 26, 2019
It is better to use gas with no ethanol as it can degrade your fuel lines. Also Ethanol is hydroscopic, it attracts moisture and sucks in moisture from the air when you winter store. If you do, then you have to use stabilizer over the winter.
https://www.google.com/search?q=ethanol+fuel+line+damage
https://fuelandfriction.com/weekend-warrior/why-use-fuel-stabilizer
Yamaha Boating | Answered on Jul 16, 2019
Either fuse, switch or pump itself. See your friendly mechanic
Yamaha Boating | Answered on Jul 14, 2019
Yamaha 2012 WaveRunner FX Cruiser SHO Logo
1 questions posted
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
View Most Popular
WaveRunner FX Cruiser SHO Yamaha
  • WaveRunner FX Cruiser SHO Yamaha
Most Popular Question
need bolt specs 98 yamaha lx1200 put
  • Boating
