20 Most Recent
GE Profile Spectra JGB920 Gas Kitchen Range Questions & Answers
IT TAKES A LONG TIME TO REACH 350 DEGREES ON MY
most likely you have a bad ignitor,remove the racks,remove the floor to the oven,remove the flame spreader,put the oven on 350,if the flame doesn't lite within 40 seconds you have a bad ignitor.i looked up your model number,it shows a round ignitor but when i look up the part number it shows a flat ignitor,call your local parts store,give them the full model number that's on the machine,open the bottom draw,look at the left or right side of the frame around the draw opening not on the draw and you'll see the model and serial numbers,give them the full model number and they will give you the correct ignitor,let me know how long it takes before the flame lites
Bake burner flutters
[ the glow coil } the ignitor is call needs replacing it'snot getting hot enugh to open the safety valve.it's no more then $45.00. Berry common problem.
The display doesn't work on my ge model JBP21GS1WH, however the burners work fine, is there a reset or something?
No reset found in the manual. You can try this and hope it works..
Turn off the circut Breaker to the stove for 5 minutes to see if it resets. Checking around the net I've only found
"Item Discontinued"
- The part is no longer sold by the manufacturer.
- The manufacturer does not stock any substitute parts to replace this one and therefore, unfortunately, we cannot obtain or recommend a substitution for this part.
- We cannot obtain the part through any other means.
Darn..
My ge stove is beeping and says bad line I unplugged and plugged it back in and still does it
If your GE stove is beeping and displaying the message "bad line," it typically indicates an issue with the electrical power supply. Here are a few troubleshooting steps you can try to resolve the problem:
- Check the Power Supply: Ensure that the stove is properly plugged into a functioning power outlet. Verify that there is no issue with the circuit breaker or fuse that supplies power to the stove. You may need to reset the circuit breaker or replace a blown fuse if necessary.
- Inspect the Power Cord: Examine the power cord for any signs of damage, such as cuts, fraying, or exposed wires. If you notice any issues, it's advisable to replace the power cord with a new one to ensure safe and reliable operation.
- Test the Outlet: If possible, try plugging the stove into a different power outlet to see if the "bad line" message persists. This step helps determine if the issue lies with the stove or the electrical supply in your home.
- Contact a Professional: If the problem persists or if you are unsure about performing further troubleshooting steps, it's recommended to contact a qualified appliance repair technician. They can diagnose the specific issue with your GE stove and provide the necessary repairs or replacements.
