20 Most Recent
Corona 23-DK Compact Heater Questions & Answers
Burns unevenly and smokes
try emptying your heater of fuel,and lighting it letting burn for several hours. This will burn all of the deposits off of the wick. Make sure your heater is outside when you do this. when done lower the wick,fill with fuel,and let the wick soak for fifteen minutes before lighting.If this doesn't work try brushing the top of the wick a light brush of some sort and light.If still no luck,change the wick.
Heater will not stay lit after firing it up.
Two things usually cause the problem you noted. An improperly installed wick or the tails of the wick are not all the way into the tank. Therefore, it won't absorb enough kerosene for it to continually burn
Check out those two things and one of the other should solve your problem.
Black smoke coming kerosene
hi dear,
First of all make sure that the heater is filled with K-1 Kerosene. Other fuel, such as gasoline, home heating oil, etc. do not burn hot, causing the heater to burn out of control. NEVER USE GASOLINE or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 Kerosene. If you are sure of your kerosene and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure your heater is not in a draft. Too much air can create a very high flame condition. Avoid placing the heater in drafty areas or under a ceiling fan. Make sure the burner chimney is seated correctly. If the burner chimney didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be raised too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned, or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact wick height. If the wick is installed correctly and there is no other obvious defect it is best to take the heater to a service center to determine the cause. Our Find a Retailer tool can be used to help find a servicing center.
I cant shut the heater off. The knob wont turn to
Try tilting the heater so the flame extinguisher snuffs it out. Please do this out side as it really does stink when it is shut off this way. After it cools please take it apart and check the wick you have a problem in your heater and something is bound up in the wick assembly. Take your time and do this outside as well because it is a messy job and kerosene stinks. Your wick should turn up and down with little to no resistance.
Diesel
well, somebody once told me that if you add a quart of oil to 5 gal of kero, it makes a good diesel substitute. So, in theory, I would add a little ethinal (corn gas) to the kero.
Wont light
Make sure you are using K-1 grade and that water had not gotten into the tank during the off season. If even when manual lighting and a lit match doesn't ignite the wick that may be the case.
