20 Most Recent
GE 30 in. JP326 Electric Cooktop Questions & Answers
How do i wire a ge cooktop
most stoves are 220 and will have four wires(red,black,white and ground). If you only have 3, black to black, ground to ground, red to white
Im trying to put the
check the design of the drip pan and make sure it in the same position and shape with the burner before trying to put in back
The "hot surface" light stays on all the time
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
We are donating our GE built-in electric cooktop
If you go with the H&R Block deduction pro it will be worth 75.00 for avarage ware up to 105 for like new. This is for the 2009 tax year. I do not know what it will be worth for the 2010 tax year as the taxes might change by then.
Good Luck and please rate 4 thumbs up for the free answer.
Defy hob
I take offense at that. I spend my optional time trying to help other people and to give them an alternative to paying a repairman for something that they could do themselves, if they gad a little guidance. Dozens of others are here regularly doing tha same thing...for free. You can get tons of information for free on this site, and you can also directly hire a tech if you need one-on-one assistance. Take a little time to go through this website again; apparently you just hit the wrong button somewhere.
By the way, what is your question?
Respectfully, sort of, Woobie Dog
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
GE electric cooktop
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
