20 Most Recent GE 36 in. Profile JP968 Electric Cooktop Questions & Answers
I have a GE profile
Same here. ALWAYS happens when I boil a whole chicken. Goes off & starts flashing about 3/4 thru. I just assumed it's to hot for to long. it's glass top. Anybody know?
9/18/2022 8:00:16 PM • GE 36 in.... • Answered on Sep 18, 2022
0answers
Error
Be the first to answer 12/30/2013 2:25:37 AM • GE 36 in.... • Posted on Dec 30, 2013Be the first to answer
I need an owners manual for jp968b0c1bb
First of all, thank you very much David for choosing FIXYA today for your online technical support needs. Here is a direct link to the ONLINE USER'S MANUAL for that model:http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80141.pdf To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual. You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer. I truly hope that was helpful to you. Good luck and take care. Joe.
2/27/2012 11:12:43 PM • GE 36 in.... • Answered on Feb 27, 2012
My GE JP968 cooktop incorrectly
I could not help the customer.
Gary
7/11/2011 12:34:29 AM • GE 36 in.... • Answered on Jul 11, 2011
Glass top is scratched and discolored...can you
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
2/3/2011 3:50:36 PM • GE 36 in.... • Answered on Feb 03, 2011
0answers
0answers
GE 30IN JS 968 DOUBLE GRIDDLE ON LEFT 9 IN FRONT
the problem is from a wire connection inside the unit. Heat may have melted the wire of the small burner that is not heating. I believe there is no power entering into the smaller burners, that's why its not heating.
You will need to open the burner, check the wire connections inside and make sure you reconnect any burnt/disconnected wire and make sure everything is in place.
Once this is done, it should heat up again.
Good luck.
6/14/2010 10:03:28 PM • GE 36 in.... • Answered on Jun 14, 2010
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
2/11/2009 7:04:29 PM • GE 36 in.... • Answered on Feb 11, 2009
Replacing Grill module with gas burner on GE Gas cooktop (PGP990)
You can't modify gas appliances.
9/27/2023 5:42:09 PM • GE Cooktops • Answered on Sep 27, 2023
Wiring for GE Cooktop 1960s
I have an early 1970s GE, and we keep saying when it breaks down, we will replace it, but apart from replacing elements, it just goes on and on. Unfortunately, neither of your numbers give results. There should be a plate near the power lead that has the details and some have a parts manual and wiring diagram in the rear of the console if it has one. https://www.google.com/search?q=GE+82212+cooktop https://www.google.com/search?q=GE+YT123887L+cooktop ..
9/17/2023 10:38:35 PM • GE Cooktops • Answered on Sep 17, 2023
2answers
Fuse location on GE Profile PP975S Cooktop (If there is one)?
Question edited for clarity. There is no fuse, the loads are too great. The Service Manual is in the link. Check the Control Lock on Page 11. https://ja.safe-manuals.com/source/pdf/adea1af72b5b020af66562d603ff2631 https://www.google.com/search?q=ge+pp975s+fuse+location ....
12/25/2022 7:57:23 AM • GE Cooktops • Answered on Dec 25, 2022
How do you remove only the maintop cover of a GE JGP963 gas cooktop? I need to replace a part, but can't remove the maintop even after unscrewing and removing every burner.
It is a gas appliance. From the installation manual. Installation and service must be performed by a qualified installer, service agency or the gas supplier. It needs to come out as there is almost certainly fixings from below. Screws on the burners, only hold the burner rings down. The installation manual doesn't say how the top comes off, just how to install. No Service Manual for it. https://www.manualslib.com/manual/57348/Ge-Jgp630.html?page=1#manual ..
12/1/2022 8:15:10 PM • GE Cooktops • Answered on Dec 01, 2022
GE 36 in. Profile JP968 Electric Cooktop Logo
19 questions posted
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
glass top scratched discolored
  • Cooktops
