20 Most Recent GE 30 in. JP328SFSS Electric Cooktop Questions & Answers
manual
manual
When I turn on the coil burner it goes to full
The switch contacts are burnt and sticking. Very common problem. The model and
serial should be behind the bottom drawer on the (right side for GE). This switch runs
around 45 dollars. I do not recommend using a "universal" as they are just a pain to install and cut the shafts.
7/30/2011 7:16:01 PM • GE 30 in.... • Answered on Jul 30, 2011
I just bought a jp328sfss
It sounds like you better be careful for starters. I also suggest your handyman sticks to painting. In older homes a 208/240 circuit onlt had three wires. New construction and remodeling requires a four wire system. Per code, a black wire is 120VAC, and a red wire is 120VAC. In a 240VAC circuit they would be called L-1 and L-2 respectively. In order to provide 240VAC they must be on seperate phases. The bare wire in your bundle is the ground wire and is at the same potential as neutral, or the white wire in current four wire systems. If you know how to use an electrical test meter, you should show 120VAC from black to bare copper, 120VAC from red to bare copper, and 240VAC from black to red. If this is not the case, I strongly suggest you have an electrician come in and take care of it in your breaker panel. *****Electricity is nothing to fool around with if you are not absolutely sure you know what you are doing. A loose connection, a wrong connection can result in fire, serious injury or death. It's worth a service call to a licensed electrician or qualified appliance service technician to give you peace of mind, and years of safe use of your new cooktop.
11/18/2010 5:54:08 AM • GE 30 in.... • Answered on Nov 18, 2010
GE JP328SFSS COOKTOP - WON'T TURN OFF
replace thermastat control
4/23/2009 5:16:13 PM • GE 30 in.... • Answered on Apr 23, 2009
Replacing Grill module with gas burner on GE Gas cooktop (PGP990)
You can't modify gas appliances.
9/27/2023 5:42:09 PM • GE Cooktops • Answered on Sep 27, 2023
Wiring for GE Cooktop 1960s
I have an early 1970s GE, and we keep saying when it breaks down, we will replace it, but apart from replacing elements, it just goes on and on. Unfortunately, neither of your numbers give results. There should be a plate near the power lead that has the details and some have a parts manual and wiring diagram in the rear of the console if it has one. https://www.google.com/search?q=GE+82212+cooktop https://www.google.com/search?q=GE+YT123887L+cooktop ..
9/17/2023 10:38:35 PM • GE Cooktops • Answered on Sep 17, 2023
2answers
Fuse location on GE Profile PP975S Cooktop (If there is one)?
Question edited for clarity. There is no fuse, the loads are too great. The Service Manual is in the link. Check the Control Lock on Page 11. https://ja.safe-manuals.com/source/pdf/adea1af72b5b020af66562d603ff2631 https://www.google.com/search?q=ge+pp975s+fuse+location ....
12/25/2022 7:57:23 AM • GE Cooktops • Answered on Dec 25, 2022
How do you remove only the maintop cover of a GE JGP963 gas cooktop? I need to replace a part, but can't remove the maintop even after unscrewing and removing every burner.
It is a gas appliance. From the installation manual. Installation and service must be performed by a qualified installer, service agency or the gas supplier. It needs to come out as there is almost certainly fixings from below. Screws on the burners, only hold the burner rings down. The installation manual doesn't say how the top comes off, just how to install. No Service Manual for it. https://www.manualslib.com/manual/57348/Ge-Jgp630.html?page=1#manual ..
12/1/2022 8:15:10 PM • GE Cooktops • Answered on Dec 01, 2022
F152 error GE Monogram electric cooktop
Take out the right front burner and use your multimeter to check it for continuity. Only then can you be sure that the error code isn't lying to you. It is my guess, that with an error message so specific, that if no burners are working, it is not the front right burner at all. Hands on testing is the only way to be sure. F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced.
error code F152 ' Appliance Video
The element is $225.00 so it is not something to change on a guess. Full testing procedure here, or call for a Service Engineer. https://www.appliancepartspros.com/answers-for-ge-element-radiant-lt-wb30t10080-ap3188020-question-148609.html ..
3/20/2022 6:27:28 PM • GE Cooktops • Answered on Mar 20, 2022
Where can I get replacement control knobs for my GE JGP636 gas Cooktop
do an online search or if a repair shop in area order from them
1/22/2022 1:33:42 PM • GE Cooktops • Answered on Jan 22, 2022
2answers
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM • GE Cooktops • Answered on Feb 17, 2021
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
11/1/2020 7:28:10 PM • GE Cooktops • Answered on Nov 01, 2020
GE Monogram Cooktop beeping with LTD and Temp flashing and an F appearing
most likely the keypad is defective.
10/3/2019 12:28:37 AM • GE Cooktops • Answered on Oct 03, 2019
Ge monogram induction cooktop error F
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element. Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
1/9/2019 10:31:53 PM • GE Cooktops • Answered on Jan 09, 2019
I have a 5 burner ge induction cook top. 3 work. The other 2 indicate a turn on signal but do not function. How do I troubleshoot
There are several helpful how-to videos on Youtube but please be aware induction hobs work on a principle different from the usual and the troubleshooting and repair is considered a specialist task - if you wouldn't poke around inside a tv or a computer then you probably shouldn't poke around inside your hob.
12/2/2018 6:26:52 PM • GE Cooktops • Answered on Dec 02, 2018
Wiring diagram ge jp350
go to this link and you should find the manual...or the diagram.. Wiring diagram ge jp350 Google Search
10/23/2017 4:02:12 PM • GE Cooktops • Answered on Oct 23, 2017
GE 30 in. JP328SFSS Electric Cooktop Logo
Popular Tags
6 questions posted
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
when turn coil burner goes full
  • Cooktops
