20 Most Recent
GE 30 in. Profile JP989 Electric Cooktop Questions & Answers
Jp989 electric cooktop burners will
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
12/21/2010 3:55:44 PM •
GE 30 in....
Answered
on Dec 21, 2010
Large section of dual burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
7/24/2010 5:43:12 PM •
GE 30 in....
Answered
on Jul 24, 2010
Burner won't shut off!!!!
The pirst thing to look at is the control knob. I would replace that. Most likly it is the problem.
12/17/2009 6:15:17 AM •
GE 30 in....
Answered
on Dec 17, 2009
GE Profile oven controls not working
As the Electric Cooktop is unable to operate properly after unplugging, it sounds like Faulty Control Board.
Replace and more likely, it would fix the problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11/26/2009 2:55:49 PM •
GE 30 in....
Answered
on Nov 26, 2009
Jp 989 switch replacement
not timely but no.
i have a dead switch, had to unhook it cause it kept tripping the breaker. 3 out of 4 work now.
can i buy 1 switch or do i need a whole new assembly. where to buy online ?
10/23/2008 3:00:14 PM •
GE 30 in....
Answered
on Oct 23, 2008
Maytag MER6770aaw
if the 9inch dont cycle off and on like the others and the 6 dont work at all replace the element
12/30/2007 1:53:50 AM •
GE 30 in....
Answered
on Dec 30, 2007
