20 Most Recent Stanley 3089 3089-13 310 MHz Garage Door Opener Remote Transmitter Canadian Version Questions & Answers
Stanley 3089... | Answered on Jun 18, 2014
Take the trim completely off that surrounds the track on top, after that you can simply lift the door up and pull to you or push the door away from you to clear it from the track! Hope that works for you Sincerely Glenn
Stanley Building... | Answered on May 13, 2014
First you must make sure the sprocket on the garage door opener is spinning clockwise and reaches its limit and stops, you can easily put a pair of pliers between the #1 and #2 terminals on the garage door opener and start the sprocket spinning or just grab a remote and watch from the back of the unit (looking towards garage door ) and make sure it,s direction is clockwise, Once it stops you wanna loosen the chain enough so you can position the carriage which is connected to the chain and with your door closed send the carriage down far enough so that the carriage and the trolley both engage then all you have to do is put the chain over the sprocket and tighten up the tensioner that is located on the trolley...not to tight and not to loose is what you would want in an adjustment !....now since you already ran the sprocket in the down position your door is now ready to test ...when you press your remote or wall station the door will travel up, You have to do it this way , if you don,t ..you can damage the machine or your door ! Good luck and hope I was able to help you with your dilemma!
Stanley Building... | Answered on May 09, 2014
Sounds like someone nearby has the same unit. Change the channels.
Building... | Answered Yesterday
Unplug the unit for 1 minute, pug in again and retry.
try using the pairing button .
Building... | Answered on Jan 20, 2020
Get a kit at any home improvement stores and the kit has cleaner, etching agent and paints too .
Building... | Answered on Jan 10, 2020
DIY Laminate Floor Cleaner Your Grandmother Would Be Proud Of ...
https://crunchybetty.com > Blog > Crunchy Home
Sep 7, 2016 - Like I said, you can either use the bucket method (where you tote it ... I used ONLY vinegar and water to clean my laminate floors before .... I've had hardwood floors at times and my very competent floor ..... It's the best thing to come out of Cuba since... my husband. ...... Tired of being cleaning their mess
Building... | Answered on Jan 09, 2020
Stanley 3089 3089-13 310 MHz Garage Door Opener Remote Transmitter Canadian Version Logo
1 questions posted
Top Stanley Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Stanley Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Building Materials
Most Popular Question
stanley manual
  • Building Materials
