20 Most Recent
Lakewood Oil-Filled Electric Radiator Heater Questions & Answers
Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
4/12/2019 2:07:39 PM •
Lakewood...
Answered
on Apr 12, 2019
I have a lakewood heater and there is a diode in
Take that circuit board to an electronics store. A REAL electronics store. The local one around my home town is called L and N electronics. I know that may not be much help, but I've learned by changing board components, that not all parts have multiple applications. I've repaired my own studio/stage speakers and amps, and those diodes and resistors/capacitors are stereo components specifically made for that application. I normally would have to replace 2-5 different components in that circuit also, not just the 1 obvious damaged part. Not sure where you are, so it's hard to point you in the right direction.
8/20/2017 2:41:57 PM •
Lakewood...
Answered
on Aug 20, 2017
Lakewood heater model 6500 the top high low knob
you can still use this heater, but continue to monitor its operation. If it gets hot enough to start smoking again, discontinue use and purchase a new one. Your safety means EVERYTHING!!!!!!
3/2/2014 6:45:18 PM •
Lakewood...
Answered
on Mar 02, 2014
